inventec comet dis 6050a2519801-mb rev x01 db1 2012.09.28
This Inventec Sharkbay motherboard, project code WUA3X01, board number 6050A2519801 revision B, is built around the Intel Haswell ULT platform. The system memory architecture consists of two DDR3/DDR3L SODIMM slots. The charging subsystem is managed by a TI BQ24736 SMBUS charger IC. The power delivery network includes multiple VR controllers such as the TPS51362, TPS51622, TPS51312, TPS51728, TPS51367, TPS51225, RT8068, G2997, FDC7692, AO6424, FDMS0310A, and AON7403. The audio codec is a Realtek ALC, the card reader controller is a GL9755, the LAN IC is an RTL8111G, and the USB hub controller is a GL3520. The motherboard supports a discrete GPU, the N14P-GT, and includes dGPU to UMA conversion capability. The EC/KBC is an ITE controller, and the BIOS is stored on a SPI flash device.
Q: What is the charging IC used on this motherboard?
A: The charging IC is a TI BQ24736, communicating via SMBUS.
A: Yes, the schematic indicates support for dGPU to UMA conversion.
A: The motherboard uses two DDR3/DDR3L SODIMM slots.
Q: What is the LAN IC on this motherboard?
A: The LAN IC is a Realtek RTL8111G.
| Brand | Inventec |
| Model | Sharkbay |
| Project Code | WUA3X01 |
| Board Number | 6050A2519801 |
| Revision | B |
| Date | 21-OCT-2002 |
| CPU Platform | Haswell ULT |
| Charging IC | TI BQ24736 |
| Charger Architecture | SMBUS |
| RAM Type | DDR3 / DDR3L |
| RAM Architecture | SODIMM x2 |
| Audio Codec | ALC (Realtek) |
| Card Reader IC | GL9755 |
| LAN IC | RTL8111G |
| WiFi / WLAN IC | Intel |
| USB Hub IC | GL3520 |
| Power IC(s) | TPS51362, TPS51622, TPS51312, TPS51728, TPS51367, TPS51225, RT8068, G2997, FDC7692, AO6424, FDMS0310A, AON7403 |
| Thermal Sensor | G2997 |
| EC / KBC | ITE |
| GPU Type | dGPU |
| dGPU Chip Number | N14P-GT |
| dGPU to UMA Conversion Support | Yes |
| Platform Alias | Sharkbar MB |
WUA3X01
6050A2519801
Haswell-ULT
BQ24736
DDR3L
GL9755
RTL8111G
GL3520
AO6424
AON7403
FDC7692
FDMS0310A
G2997
RT8068
TPS51225
TPS51312
TPS51362
TPS51367
TPS51622
TPS51728
G2997
N14P-GT
Sharkbar MB
WUA3X01
6050A2519801
Haswell-ULT
BQ24736
DDR3L
GL9755
RTL8111G
GL3520
AO6424
AON7403
FDC7692
FDMS0310A
G2997
RT8068
TPS51225
TPS51312
TPS51362
TPS51367
TPS51622
TPS51728
G2997
N14P-GT
Sharkbar MB
