ibm x200 x200e wistron mp1 mocha1 lmc mb 07226-1-1final 91.47q01.001 schematic 1
This Wistron Mocha-1 reference design is built around the Intel Cantiga-GM platform with a Penryn SV processor and an Intel ICH9-M southbridge. The system memory architecture consists of DDR3 1067/800MHz memory, supporting both Channel A and Channel B via unbuffered 204-pin DDR3 SODIMM modules in reverse and normal socket configurations. The embedded controller is a Renesas H8S/2116 in a BG20V package, communicating over the LPC bus. The BIOS is stored on a SPI-FLASH device. Power management is handled by a TPS51221 system DC/DC converter, a VT1311 CPU core regulator, and an ADP3808 battery charger/selector. Integrated graphics are provided by the Cantiga-GM GMCH GFX core. The board includes a USB2514 USB hub controller, a MAX6694 and LM26 thermal sensors, a WINBOND Super I/O, and an MLF68 clock generator. The PCB raw card number is 48.47Q01.001 with project code 91.47Q01.001.
A: The embedded controller is a Renesas H8S/2116 in a BG20V package.
A: The board supports DDR3 1067/800MHz memory in dual-channel configuration using unbuffered 204-pin DDR3 SODIMM modules.
A: The charging IC is an ADP3808 battery charger/selector.
| Project Code | Mocha-1 |
| Document Number | A3162 |
| Date | Thursday, May 08, 2008 |
| CPU Platform | Intel Cantiga-GM |
| CPU Model | Penryn SV |
| PCH / Southbridge | Intel ICH9-M |
| EC / KBC | H8S/2116 |
| EC/KBC Package | BG20V |
| BIOS / SPI Flash | SPI-FLASH |
| Charging IC | ADP3808 |
| Charger Architecture | Battery Charger/Selector |
| Power IC(s) | TPS51221, VT1311, VT351, BD3550, MAX1510 |
| RAM Architecture | 1067/800MHz, Channel A, Channel B, UNBUFFERED DDR3 SODIMM |
| RAM Quantity / Slots | 204-PIN DDR3 SODIMM, Reverse Socket, Normal Socket |
| Thermal Sensor | MAX6694, LM26 |
| Card Reader IC | Media Card Reader 3-in-1 Slot |
| USB Hub IC | USB2514 |
| LAN IC | GLAN BOAZMAN |
| WiFi / WLAN IC | WLAN Card |
| Audio Codec | Audio Codec |
| Super I/O | WINBOND |
| Clock Generator | MLF68 |
| GPU Type | INTEGRATED GRAHPICS |
| Graphics Architecture | GMCH GFX CORE |
| Board Number | 48.47Q01.001 |
| Project Code (Alternate) | 91.47Q01.001 |
MOCHA-1
Cantiga
Penryn SV
ICH9
H8S/2116
ADP3808
BD3550
MAX1510
TPS51221
VT1311
VT351
MAX6694, LM26
USB2514
MLF68
INTEGRATED GRAHPICS
GMCH GFX CORE
48.47Q01.001
MOCHA-1
Cantiga
Penryn SV
ICH9
H8S/2116
ADP3808
BD3550
MAX1510
TPS51221
VT1311
VT351
MAX6694, LM26
USB2514
MLF68
INTEGRATED GRAHPICS
GMCH GFX CORE
48.47Q01.001
