ibm thinkpad l410 quanta gc7 rev 1a
The Quanta G-Note Montevina (R410) motherboard, revision 1A, dated September 3, 2009, is built around the Intel Penryn 478P (uPGA) CPU platform with a Cantiga northbridge and ICH-9M southbridge. Graphics are handled by integrated GL40/GM45 GPU. The system uses two DDRIII-SODIMM slots supporting 800/1066 MT/s memory. The embedded controller is an IT8502E/JX from ITE. Audio is managed by an ALC269Q codec, while networking is provided by a Realtek RTL8111DL/RTL8103EL LAN IC. The charging IC is an ISL88731A, with power regulation handled by ISL6266A, RT8204, TPS51116, and ISL6237. The BIOS is stored on an SPI EEPROM (ITPM). A JMB385 card reader controller and a discrete TPM module are also present. The clock generator is an SLG8SP568/ICS9LPRS393 in a QFN68 package.
A: The embedded controller is an ITE IT8502E/JX.
Q: What BIOS/SPI flash configuration is used?
A: The BIOS is stored on an SPI EEPROM (ITPM).
Q: What charging IC is used?
A: The system charger is an ISL88731A.
Q: What power management ICs are present?
A: Power regulation includes ISL6266A (CPU core), RT8204 (VCCP +1.8V and GMCH 1.05V), TPS51116 (DDR III), and ISL6237 (system power).
| Model | G-Note Montevina |
| Project Code | R410 Montevina |
| Board Number | 1122334455667788AABBCCDD |
| Revision | 1A |
| Date | Thursday, September 03, 2009 |
| PCH / Southbridge | ICH-9M |
| GPU Type | GL40/GM45 |
| EC / KBC | IT8502E/JX |
| Audio Codec | ALC269Q |
| BIOS / SPI Flash | SPI EEPROM (ITPM) |
| Charging IC | ISL88731A |
| Power IC(s) | ISL6266A, RT8204, TPS51116, ISL6237 |
| RAM Type | DDRIII 800/1066 MT/s |
| RAM Architecture | DDRIII-SODIMM1, DDRIII-SODIMM2 |
| Card Reader IC | JMB385 |
| LAN IC | RTL8111DL/RTL8103EL |
| WiFi / WLAN IC | WLAN/WiMAX |
| Thermal Sensor | CPU THERMAL SENSOR |
| Clock Generator | SLG8SP568/ICS9LPRS393 (QFN68) |
| Northbridge | Cantiga |
| EC EEPROM | ALC269Q |
| G-Sensor | LIS244ALTR |
| TPM | Discrete TPM |
R410
Penryn
ICH-9M
GL40
GM45
IT8502E/JX
ALC269Q
ISL88731A
ISL6237
ISL6266A
RT8204
TPS51116
JMB385
RTL8103EL
RTL8111DL
ICS9LPRS393
SLG8SP568
LIS244ALTR
Motion / Position Sensor
R410
Penryn
ICH-9M
GL40
GM45
IT8502E/JX
ALC269Q
ISL88731A
ISL6237
ISL6266A
RT8204
TPS51116
JMB385
RTL8103EL
RTL8111DL
ICS9LPRS393
SLG8SP568
LIS244ALTR
