ibm t410 t410i nozomi-1 ext 512mb sovp nzm1e-8 ver 8.00 lnz dis4 schematic 1
This Lenovo Nozomi-1 Ext 512MB motherboard, board number 60Y3480 revision 8.00 dated February 9, 2010, is built around the N10M-NS GPU platform. The system uses DDR3 memory in two SODIMM slots. The embedded controller is a Renesas H8S/2112, and the audio codec is a Conexant CX20585. The charging architecture is managed by a Texas Instruments BQ24741 charger IC. Power regulation is handled by multiple ICs including the ADP3212 for VCCCPU core, ADP3211 for VCCGFX core, TPS51222 for VCC5M/VCC3M, VT357 for VCC1R05B_VTT, VT356 for VCC1R05LAN, VCC1R5A, and VCC1R5VIDEO, MAX1510 for VCC0R75B, and BD3551 for VCC1R8VIDEO and VCC1R8B. The LAN controller is an Intel Hanksville GbE. The system includes a MediaCard interface, DisplayPort mux, and a Thinker-1 thermal sensor. SPI flash is used for both the BIOS and EC firmware storage.
A: The embedded controller is a Renesas H8S/2112.
A: The charging IC is a Texas Instruments BQ24741.
A: The audio codec is a Conexant CX20585.
Q: What is the memory configuration for this motherboard?
A: The motherboard uses DDR3 memory in two SODIMM slots.
Q: What is the GPU platform on this motherboard?
A: The GPU platform is N10M-NS.
| Brand | Lenovo |
| Model | Nozomi-1 Ext 512MB |
| Motherboard Manufacturer | Lenovo |
| Project Code | NZM1EXT512MB |
| Board Number | 60Y3480 |
| Revision | VER 8.00 |
| Date | 02/09/2010 |
| CPU Platform | N10M-NS |
| EC / KBC | H8S/2112 |
| Charging IC | BQ24741 |
| Audio Codec | CX20585 |
| LAN IC | Hanksville |
| RAM Architecture | SODIMM |
| Thermal Sensor | Thinker-1 |
| Card Reader IC | MediaCard Interface |
| USB Hub IC | USB Power/Conn |
| WiFi / WLAN IC | LoadSW WAN & WLAN |
| HDMI Level Shifter | DisplayPort Mux |
| GPU Type | N10M-NS |
| Graphics Architecture | N10M-NS |
| dGPU Chip Number | N10M-NS |
| Power IC(s) | ADP3212, ADP3211, TPS51222, VT357, VT356, MAX1510, BD3551 |
| Charger Architecture | BQ24741 |
| EC Flash / ROM | SPI Flash |
NZM1EXT512MB
60Y3480
N10M-NS
H8S/2112
BQ24741
CX20585
THINKER-1
N10M-NS
N10M-NS
ADP3211
ADP3212
BD3551
MAX1510
TPS51222
VT356
VT357
NZM1EXT512MB
60Y3480
N10M-NS
H8S/2112
BQ24741
CX20585
THINKER-1
N10M-NS
N10M-NS
ADP3211
ADP3212
BD3551
MAX1510
TPS51222
VT356
VT357
