ibm t410 nzm1 nzm1i-3 int siv v321 0513 wsn 09a21-sa uma schematic 1
This Lenovo Nozomi-1 INT SIV schematic, revision VER.3.21 dated 05/13/09, details the NZM1I-3 motherboard based on the Intel Arrandale CPU platform. The system management is handled by a Renesas H8S/2112 EC/KBC, while audio processing is managed by a Conexant CX20585 codec. Power management includes a BQ24741 battery charger and multiple DC/DC converters such as the ADP3212 for CPU core, TPS51222 for 5V/3.3M, MAX1510, BD3551, VT356, and VT357. The memory subsystem consists of two DDR3 SODIMM channels. The integrated LAN controller is identified as Hanksville. Additional onboard components include a thermal sensor, card reader controller, TPM module, and G-sensor.
Q: What EC/KBC is used on this Lenovo Nozomi-1 motherboard?
A: The EC/KBC is a Renesas H8S/2112.
A: The audio codec is a Conexant CX20585.
Q: What is the charging IC and architecture for this board?
A: The charging IC is a BQ24741, configured as a battery charger.
Q: What power ICs are used for voltage regulation?
A: Key power ICs include the ADP3212 for CPU core, TPS51222 for 5V/3.3M, MAX1510, BD3551, VT356, and VT357.
| Brand | Lenovo |
| Project Code | Nozomi-1 |
| Board Number | NZM1I-3 |
| Revision | VER.3.21 |
| Date | 05/13/09 |
| CPU Platform | Intel Arrandale |
| EC / KBC | H8S/2112 |
| Audio Codec | Conexant CX20585 |
| Charging IC | BQ24741 |
| Charger Architecture | Battery Charger |
| Power IC(s) | ADP3212, TPS51222, MAX1510, BD3551, VT356, VT357 |
| RAM Architecture | SODIMM |
| LAN IC | Hanksville |
| Thermal Sensor | Yes |
| Card Reader IC | Yes |
| TPM | Yes |
| G-Sensor | Yes |
