Schematic HP ZBook 17 G3 LA-C381P LA-C382P Schematic
BrandCompal
ModelAPW50
Board NumberLA-C382P
Revision0.2
Date2016/03/08
CPU PlatformIntel Skylake-H 4+4e Processor with SPT-H_PCH
PCH / SouthbridgeIntel SPT-H_PCH
GPU TypeSkylake-H 4+2 (DIS)
Graphics ArchitectureMXM 3.0 Conn PEG x16
EC / KBCNPCE586HA0MX
EC/KBC ProgrammableeSPI
Audio CodecALC3268
BIOS / SPI FlashW25Q128FVSIQ
BIOS Flash Capacity128 Mbit (16 MB)
EC Flash / ROMW25Q64FVSSIQ
Charging ICTPS65982
Charger ArchitectureType-C PD
Power IC(s)TPS2546RTER
RAM TypeDDR4 SODIMM
RAM ArchitectureDual Channel (Ch A, Ch B)
RAM Quantity / Slots2
Card Reader ICRTS5258S
LAN ICWGI219LM
WiFi / WLAN ICIntel Alpine Ridge 4C(Host)
HDMI Level ShifterIT6515FN
Thermal SensorNCT7718W
This Compal LA-C382P Rev 0.2 motherboard, model APW50, is built around the Intel Skylake-H 4+4e processor with SPT-H PCH, supporting a discrete GPU via an MXM 3.0 PEG x16 slot. The system firmware is stored on a W25Q128FVSIQ SPI flash, while the EC firmware resides on a separate W25Q64FVSSIQ flash. The embedded controller is an NPCE586HA0MX, programmable through eSPI. Memory architecture consists of two DDR4 SODIMM slots operating in dual-channel mode. Type-C PD charging is managed by a TPS65982 controller, with a TPS2546RTER for USB charging. The audio subsystem is driven by an ALC3268 codec, and networking is provided by an WGI219LM LAN IC. Display connectivity includes an IT6515FN HDMI level shifter, and thermal monitoring is handled by an NCT7718W sensor.
A: The BIOS SPI flash is a Winbond W25Q128FVSIQ.
A: Yes, the NPCE586HA0MX EC is programmable via eSPI.
Q: What is the EC flash IC model?
A: The EC flash is a Winbond W25Q64FVSSIQ.
Q: What charging architecture does this motherboard use?
A: Type-C PD charging is implemented using a TPS65982 controller.
  • HP ZBook 17 G3 LA-C381P LA-C382P Schematic.pdf
