hp touchsmart 610 aio quanta wj1
This Quanta B15 motherboard is designed for the LGA1155 socket supporting both Sandy Bridge and Ivy Bridge CPU platforms, paired with the Cougar Point H67 PCH. Memory architecture consists of DDR3 1066/1333 MT/s across four DDR3-SODIMM slots. The embedded controller is an ITE IT8519E, with the system BIOS stored on an SPI ROM. Audio is handled by the IDT 92HD89D codec with SSM2306 amplification. Networking is provided by the RT8111E Gigabit LAN controller, and USB 3.0 connectivity is managed by the UPD720200 hub. The board features an RTS5138 card reader, STDP4010 DP to LVDS converter for display output, and NCP6151S, TPS51116, and RT8206 power ICs for voltage regulation. A Cypress CG7216AM microcontroller and DRV604 fan controller are also present.
A: The embedded controller is an ITE IT8519E.
A: The audio codec is IDT 92HD89D, and the audio amplifier is SSM2306.
A: The charging IC is RT8206.
Q: What is the card reader IC?
A: The card reader IC is RTS5138.
| Project Code | B15 |
| Date | Monday, October 18, 2010 |
| CPU Platform | Ivy Bridge / Sandy Bridge |
| CPU Socket | LGA1155 |
| PCH / Southbridge | Cougar Point H67 |
| EC / KBC | ITE IT8519E |
| Audio Codec | IDT 92HD89D |
| Charging IC | RT8206 |
| Power IC(s) | NCP6151S, TPS51116, RT8206 |
| RAM Architecture | DDR3 1066/1333 MT/s |
| RAM Quantity / Slots | DDR3-SODIMM 1&2, DDR3-SODIMM 3&4 |
| Card Reader IC | RTS5138 |
| USB Hub IC | UPD720200 |
| LAN IC | RT8111E |
| WiFi / WLAN IC | Mini PCI-E (WLAN/TV) |
| HDMI Level Shifter | STDP4010 |
| Audio Amplifier | SSM2306 |
| uC | CG7216AM |
| Fan Controller | DRV604 |
| Thermal Protection | FAN/Thermal Protection |
B15
Ivy Bridge
Sandy Bridge
LGA1155
H67
IT8519E
92HD89D
RT8206
NCP6151S
RT8206
TPS51116
RTS5138
UPD720200
RT8111E
STDP4010
SSM2306
DRV604
B15
Ivy Bridge
Sandy Bridge
LGA1155
H67
IT8519E
92HD89D
RT8206
NCP6151S
RT8206
TPS51116
RTS5138
UPD720200
RT8111E
STDP4010
SSM2306
DRV604
