hp pavilion x360 compal zpt10 la-b151p rev 1.0 2014-01-14
This Compal LA-B151P Rev 1.0 motherboard, dated 2014-01-14, is built on the Intel Bay Trail M platform with a VALLEYVIEW-M UMA graphics architecture. The system memory is configured as a single channel DDR3L 1333MHz via one SO-DIMM slot. The embedded controller is an ENE KB9012QF-A4, and the audio codec is an ALC3227-CG. Networking is handled by a Realtek RTL8166EH-CG LAN controller. The board features a Realtek RTS5237-GR card reader, an IT8350E sensor hub, a RTD2132N LVDS translator, a TPA6133 audio amplifier, APX9132H hall sensors, a STK8313 G sensor, and a SLB9656 TPM module. The BIOS is an 8M SPI flash.
Q: What is the board number and revision for this motherboard?
A: The board number is LA-B151P, revision 1.0.
A: The EC/KBC is an ENE KB9012QF-A4.
Q: What is the memory configuration for this motherboard?
A: The memory is single channel DDR3L 1333MHz via one SO-DIMM slot.
Q: What is the BIOS flash capacity?
A: The BIOS flash is 8M.
| Model | Intel Bay Trail M ZPT10 UMA M/B |
| Board Number | LA-B151P |
| Date | 2014-01-14 |
| CPU Platform | Intel Bay Trail M |
| EC / KBC | ENE KB9012QF-A4 |
| Audio Codec | ALC3227-CG |
| BIOS / SPI Flash | BIOS (8M) |
| LAN IC | RTL8166EH-CG |
| Card Reader IC | RTS5237-GR |
| RAM Type | DDR3L 1333MHz |
| RAM Architecture | Single Channel |
| RAM Quantity / Slots | 1 |
| GPU Type | UMA |
| Graphics Architecture | VALLEYVIEW-M |
| Sensor Hub | IT8350E |
| LVDS Translator | RTD2132N |
| Audio Amplifier | TPA6133 |
| Hall Sensor | APX9132H |
| G Sensor | STK8313 |
| TPM | SLB9656 |
LA-B151P
Bay Trail-M
KB9012QF A4
ALC3227-CG
RTL8166EH-CG
RTS5237-GR
Valleyview-M
IT8350E
Motion / Position Sensor
TPA6133
Audio Amplifier
APX9132H
STK8313
SLB9656
LA-B151P
Bay Trail-M
KB9012QF A4
ALC3227-CG
RTL8166EH-CG
RTS5237-GR
Valleyview-M
IT8350E
TPA6133
Audio Amplifier
APX9132H
STK8313
SLB9656
