hp mini 210 quanta_miata1.0_rev1a schematic
hp mini 210=1=quanta_miata1.0_rev1a.pdf
This Quanta Miata 1.0 motherboard is built around the Intel Pineview-M platform, integrating an Intel Atom processor with GMA 3150 graphics in a Micro-FCBGA8 package. The system is supported by an Intel Tigerpoint southbridge and utilizes a single DDR3 SO-DIMM slot supporting up to 2GB at 667MT/s in single-channel configuration. The embedded controller is an ITE8518, and system management is handled by an SPI flash BIOS. Audio is provided by a Realtek ALC269 codec, while networking is managed by a Realtek RTL8105 LAN controller. Power management includes an OZ8681LN system charger, an RT8152FGQW CPU core regulator, an RT8207 DDR3 power IC, and an RT8223 system power IC. The clocking solution is an ICS9LRS3165BKLFT clock generator. Storage and expansion are supported via SATA, PCI-Express, and USB 2.0 interfaces, with a GL9661 card reader controller and an AzureWave AW-NE238 WLAN module.
A: The embedded controller is an ITE8518.
A: The system charger IC is an OZ8681LN.
Q: What is the clock generator model?
A: The clock generator is an ICS9LRS3165BKLFT.
A: It supports a single DDR3 SO-DIMM slot in single-channel mode, up to 2GB at 667MT/s.
| Project Code | Miata |
| Revision | 1A |
| Date | Friday, April 01, 2011 |
| CPU Platform | Intel Pineview-M |
| EC / KBC | ITE8518 |
| Audio Codec | ALC269 |
| LAN IC | RTL8105 |
| Charging IC | OZ8681LN |
| Power IC(s) | RT8152FGQW, RT8207, RT8223 |
| RAM Quantity / Slots | 1x SO-DIMM |
| Card Reader IC | GL9661 |
| Clock Generator | ICS9LRS3165BKLFT |
| WiFi / WLAN IC | AzureWave AW-NE238 |
| GPU Type | Integrated (Intel Pineview-M) |
| Graphics Architecture | Intel GMA 3150 |
| PCH / Southbridge | Intel Tigerpoint |
| CPU Model | Intel Atom N455/N475 |
| CPU Socket | Micro-FCBGA8 |
| RAM Max Capacity | 2GB |
| RAM Speed | 667MT/s |
| PCB Layer Count | 6 |
| Document Number | 5544332211DDCCBBAA |
Pineview-M
IT8518
ALC269
RTL8105
OZ8681LN
RT8152FGQW
RT8207
RT8223
GL9661
ICS9LRS3165BKLFT
AzureWave AW-NE238
Intel GMA 3150
MICRO-FCBGA8
Pineview-M
IT8518
ALC269
RTL8105
OZ8681LN
RT8152FGQW
RT8207
RT8223
GL9661
ICS9LRS3165BKLFT
AzureWave AW-NE238
Intel GMA 3150
MICRO-FCBGA8
