hp hdx 18 quanta ut7d_ut7_rev3a schematic
hp hdx 18=1=quanta ut7d_rev3a.pdf
This Quanta UT7D NB5 motherboard, revision 3A dated August 15, 2008, is built around the Intel Penryn 478P (uPGA)/45W CPU platform paired with the ICH9-M southbridge. Graphics are handled by a discrete nVIDIA NB9P-GS 128 Bit PM45 GPU. The system uses an ENE KBC for embedded controller functions and an IDT92HD71B7X3X1X1 audio codec. Memory architecture consists of two DDR3 SODIMM slots supporting 800/1066 MHz. The BIOS is stored on SPI flash. Power management is handled by a suite of ICs including the ISL6237IRZ-T, Oz8118, ISL6266A, TPS51116REGR, and RT8204, with the ISL6251AHAZ-T managing system charging. Networking is provided by a Realtek RTL 8111C LAN controller, and a JMicron ALPRS355B MLF64PIN serves as the card reader controller.
A: The motherboard uses an ENE KBC as the embedded controller/keyboard controller.
A: The audio codec is an IDT92HD71B7X3X1X1.
A: The system charger IC is an ISL6251AHAZ-T.
Q: What is the LAN IC on this motherboard?
A: The LAN controller is a Realtek RTL 8111C.
| Project Code | UT7D |
| Board Number | NB5 |
| Revision | 3A |
| Date | Friday, August 15, 2008 |
| CPU Platform | Penryn 478P (uPGA)/45W |
| GPU Type | nVIDIA NB9P-GS 128 Bit PM45 |
| EC / KBC | ENE KBC |
| Audio Codec | IDT92HD71B7X3X1X1 |
| BIOS / SPI Flash | SPI |
| Charging IC | ISL6251AHAZ-T |
| Power IC(s) | ISL6237IRZ-T, Oz8118, ISL6266A, TPS51116REGR, RT8204 |
| RAM Architecture | SODIMM |
| LAN IC | RTL 8111C |
| Card Reader IC | ALPRS355B MLF64PIN |
| Audio Amplifier | TPA6020A2, TPA3007D1 |
| Thermal Sensor | CPU THERMAL SENSOR |
UT7D
NB5
Penryn
ICH9
IDT92HD71B7X3X1X1
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6266A
OZ8118
RT8204
TPS51116REGR
RTL8111C
ALPRS355B MLF64PIN
TPA3007D1
TPA6020A2
UT7D
NB5
Penryn
ICH9
IDT92HD71B7X3X1X1
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6266A
OZ8118
RT8204
TPS51116REGR
RTL8111C
ALPRS355B MLF64PIN
TPA3007D1
TPA6020A2
