hp cq60 cq70 g50 g60 g60t warrior sf 0605 07239-sf 1
The Wistron WarriorSF motherboard, project code 91.4H501.001 and PCB P/N 07239 revision SF, is an Intel UMA platform designed around the Penryn SV CPU and Cantiga-GM/GL chipset with integrated graphics. The southbridge is an ICH9-M, and system memory consists of dual-channel DDRII 667/800 across two slots. The embedded controller is a Winbond WPCE773L communicating via LPC, while the BIOS is stored on a 2MB Flash ROM accessible through SPI. Audio is handled by a CX20561-14Z HD Audio Codec, and networking includes a Realtek RTL8102E 10/100/1000 Ethernet controller alongside an 802.11a/b/g/n Mini-Card wireless module. The charging subsystem uses a MAX8731 charger IC, and the power delivery network includes ISL6269CCRZ, TPS51116, TPS51120, SC412A, and APL5912 regulators. A Realtek RTS5158E card reader and an ICS9LPRS355 clock generator complete the core component set.
A: The Winbond WPCE773L is used as the embedded controller.
A: The motherboard uses a 2MB Flash ROM connected via SPI.
A: The board supports dual-channel DDRII 667/800 memory across two slots (Slot 0 and Slot 1).
Q: What charging IC is used?
A: The charging subsystem is built around a MAX8731 charger IC.
| Model | WarriorSF |
| Project Code | 91.4H501.001 |
| Board Number | 07239 |
| Revision | SF |
| Date | Wednesday, May 28, 2008 |
| CPU Platform | Intel Penryn SV |
| GPU Type | Intel Cantiga-GM/GL |
| EC / KBC | Winbond WPCE773L |
| Audio Codec | CX20561-14Z |
| BIOS / SPI Flash | 2MB Flash ROM |
| Charging IC | MAX8731 |
| Charger Architecture | MAXIM CHARGER |
| Power IC(s) | ISL6269CCRZ, TPS51116, TPS51120, SC412A, APL5912 |
| RAM Type | DDRII 667/800 |
| Card Reader IC | Realtek RTS5158E |
| LAN IC | Realtek RTL8102E |
| WiFi / WLAN IC | 802.11a/b/g/n Mini-Card |
| Clock Generator | ICS9LPRS355 |
| Document Number | A3142 |
91.4H501.001
07239
Penryn
ICH9
Intel Cantiga GM
Intel Cantiga-GL
UMA
WPCE773L
CX20561-14Z
MAX8731
APL5912
ISL6269CCRZ
SC412A
TPS51116
TPS51120
RTS5158E
RTL8102E
ICS9LPRS355
91.4H501.001
07239
Penryn
ICH9
Intel Cantiga GM
Intel Cantiga-GL
UMA
WPCE773L
CX20561-14Z
MAX8731
APL5912
ISL6269CCRZ
SC412A
TPS51116
TPS51120
RTS5158E
RTL8102E
ICS9LPRS355
