hp bdl50 la-d704p rev 4.0
This Compal LA-D704P reference design, project Diner_Crepe1.1(15"), is a Kabylake-U / Skylake-U platform supporting Intel ULV processors in a 1356PBGA socket. The board utilizes DDR4 memory in a dual-channel interleaved configuration across two SO-DIMM slots. Graphics are handled by an AMD VRAM solution using gDDR3 memory across four chips. The embedded controller is an ENE KB9022Q, and the BIOS SPI flash is located at UC1 with a capacity of 256Mbx16 (4Gb). Power management is distributed across multiple DC/DC converters including RT8243AZQW, RT8880, SY8286, NCP81206, RT8207P, SY8032A, and RT8027P, with charging handled by a BQ24725 IC supporting 3S1P or 4S1P battery configurations. Audio is provided by an ALC3227 codec, and networking includes an RTL8111HSH Gigabit or RTL8166EH 10/100 LAN controller. The board also integrates an RTS5141 card reader, an RTD2168 DP to VGA transmitter, an RTD2132N eDP to LVDS transmitter, an NCT7718W thermal sensor, and an SLB9665TT2.0 TPM module.
Q: What is the board number and project name for this motherboard?
A: The board number is LA-D704P, and the project name is Diner_Crepe1.1(15").
| Model | Diner_Crepe1.1(15") |
| Project Code | Diner_Crepe1.1(15") |
| Board Number | LA-D704P |
| Revision | v0.2 |
| Date | 2016/05/11 |
| CPU Platform | Kabylake-U / Skylake-U |
| CPU Socket | 1356PBGA |
| PCH / Southbridge | Kabylake-UM/B |
| GPU Type | AMD VRAM gDDR3 x4pcs |
| EC / KBC | ENE KB9022Q |
| Audio Codec | ALC3227 |
| BIOS / SPI Flash | UC1 |
| BIOS Flash Capacity | 256Mbx16(4Gb) |
| Charging IC | BQ24725 |
| Charger Architecture | 3S1P / 4S1P |
| Power IC(s) | RT8243AZQW, RT8880, SY8286, NCP81206, RT8207P, SY8032A, RT8027P |
| RAM Architecture | Dual Channel Interleaved |
| Card Reader IC | RTS5141 |
| LAN IC | RTL8111HSH(Giga) / RTL8166EH(10/100) |
| WiFi / WLAN IC | JWLAN1 |
| HDMI Level Shifter | RTD2168 |
| Thermal Sensor | NCT7718W |
| TPM | SLB9665TT2.0 |
| eDP to LVDS Transmitter | RTD2132N |
| DP to VGA Transmitter | RTD2168 |
DINER_CREPE1.1
LA-D704P
Kaby Lake-U
Skylake-U
1356PBGA
KB9022Q
ALC3227
UC1
BQ24725
NCP81206
RT8027P
RT8207P
RT8243AZQW
RT8880
SY8032A
SY8286
RTS5141
RTL8111HSH
RTL8166EH
JWLAN1
RTD2168
NCT7718W
SLB9665TT2.0
DINER_CREPE1.1
LA-D704P
Kaby Lake-U
Skylake-U
1356PBGA
KB9022Q
ALC3227
UC1
BQ24725
NCP81206
RT8027P
RT8207P
RT8243AZQW
RT8880
SY8032A
SY8286
RTS5141
RTL8111HSH
RTL8166EH
JWLAN1
RTD2168
NCT7718W
SLB9665TT2.0
