Schematic hp 8530p inventec vb 1.0 6050a2096501 schematic
hp 8530p inventec vb 1.0_6050a2096501 schematic
hp 8530p=1=inventec vb 1.0_6050a2096501.pdf
BrandInventec
Motherboard ManufacturerInventec
Project CodeVB10
Board NumberCSA3641
RevisionA04
Date22-May-2007
Document NumberPC3601
CPU PlatformMerom 478
PCH / SouthbridgeICH8-M
EC / KBCKBC1070
Audio CodecALC861
Charging ICBQ24703
Power IC(s)TPS51120, APL5913, TPS51124, ADP3208, SC471, G9338, G2998F11U
RAM TypeDDR2
RAM ArchitectureSODIMM
RAM Quantity / Slots2
LAN ICIntel 82566MM
Card Reader ICRICOH_R5C853
GPU TypeDiscrete
Graphics ArchitecturePCI Express
This Inventec VB10 motherboard, documented under board number CSA3641 revision A04, is designed for the Intel Merom 478 CPU platform paired with the ICH8-M southbridge. The system utilizes two DDR2 SODIMM slots for memory expansion. Power management is handled by a discrete charging solution using the BQ24703 charger IC, alongside multiple power ICs including the TPS51120, APL5913, TPS51124, ADP3208, SC471, G9338, and G2998F11U. The embedded controller is identified as the KBC1070. Audio is managed by the ALC861 codec, and wired networking is provided by the Intel 82566MM Gigabit LAN controller. The discrete graphics subsystem connects via PCI Express. Storage and peripheral connectivity are supported by the ICH8-M, with a RICOH_R5C853 card reader controller for flash media.
Q: What is the board number and revision for this Inventec motherboard?
A: The board number is CSA3641, revision A04.
A: The embedded controller is the KBC1070.
A: The charging IC is the BQ24703.
A: The motherboard uses two DDR2 SODIMM slots.
  • HP 8530p=1=INVENTEC VB 1.0_6050A2096501.zip
