hp 6535s inventec zygo zodiac mv2 ver x02 schematic
This Inventec Prince/Pearl reference design, documented under board number CSA3535 SI 1X02 revision X02 dated 2008/02/14, is built around the AMD Griffin platform with an S1G2 Socket/638pin CPU. The platform integrates an RS780 GPU connected via HyperTransport A-LINK and an SB700 Southbridge. System management is handled by an SMSC KBC1091 EC/KBC, while the BIOS resides on SPI flash. Memory configuration consists of two DDR2 SODIMM slots. Power management is comprehensive, utilizing a TI BQ24740 QFN-28P charger IC supporting selectable 12.6V or 16.8V charging voltages, alongside multiple power ICs including TPS51120, APL5913, G2997, G916, MAX17009, TPS51117, and TPS51124. Audio is provided by an ADI_1984A codec, networking by a Marvell 8039 NIC, and media card reading by an ALCOR AU6371 controller. Clock generation is handled by an ICS9LPR476KLF generator.
Q: What is the board number and revision for this Inventec motherboard?
A: The board number is CSA3535 SI 1X02, revision X02, dated 2008/02/14.
A: The EC/KBC is an SMSC KBC1091.
Q: What is the charging IC and its configuration?
A: The charging IC is a TI BQ24740 in a QFN-28P package. It supports Icharger=3A with selectable Vcharger: 12.6V when CELLSEL#=0, or 16.8V when CELLSEL#=1.
A: The motherboard uses DDR2 memory with two SODIMM slots, designated DDR II _SODIMM0 and DDR II _SODIMM1.
| Project Code | Prince/Pearl |
| Board Number | CSA3535 SI 1X02 |
| Revision | X02 |
| Date | 2008/02/14 |
| CPU Platform | AMD Griffin |
| CPU Socket | S1G2 Socket/638pin |
| PCH / Southbridge | SB700 |
| GPU Type | RS780 |
| Graphics Architecture | HyperTransport A-LINK |
| EC / KBC | SMSC KBC1091 |
| Audio Codec | ADI_1984A |
| BIOS / SPI Flash | SPI |
| Charging IC | TI_BQ24740_QFN_28P |
| Charger Architecture | Icharger=3A, CELLSEL#=0, Vcharger=12.6V; CELLSEL#=1, Vcharger=16.8V |
| Power IC(s) | TPS51120, APL5913, G2997, G916, MAX17009, TPS51117, TPS51124 |
| RAM Type | DDR2 |
| RAM Architecture | DDR II _SODIMM0, DDR II _SODIMM1 |
| Card Reader IC | ALCOR AU6371 |
| LAN IC | Marvell 8039 |
| WiFi / WLAN IC | MINI CARD |
| Clock Generator | ICS9LPR476KLF |
| Thermal Sensor | Accelerometer |
| USB Hub IC | USB2.0 |
CSA3535 SI 1X02
Griffin
S1G2
SB700
RS780
KBC1091
1984A
BQ24740_QFN_28P
APL5913
G2997
MAX17009
TPS51117
TPS51120
TPS51124
AU6371
8039
ICS9LPR476KLF
USB2.0
CSA3535 SI 1X02
Griffin
S1G2
SB700
RS780
KBC1091
1984A
BQ24740_QFN_28P
APL5913
G2997
MAX17009
TPS51117
TPS51120
TPS51124
AU6371
8039
ICS9LPR476KLF
USB2.0
