hp 510 511 inventec vulcain uma_rev ax1 schematic
hp 510 511=1=inventec vulcain uma_rev ax1.pdf
The Inventec Vulcain UMA motherboard, documented under board number CSD502AX1000 and revision A01, is a Penryn platform design dated 26-Dec-2008. It features an ICH8-M southbridge and integrated 965GM graphics, supporting UMA configuration. The system employs a BQ24703-based charger architecture with power delivery managed by TPS51120, APL5913, TPS51117, ADP3208, TPS51124, and G2997 power ICs. Memory architecture consists of two DDR2 SODIMM slots. The embedded controller is a KBC1070, and the audio codec and card reader are handled by an ALCOR AU6433. Networking is provided by a Marvell LAN controller and a Mini Card WLAN interface. The system BIOS is stored in a dedicated SPI flash. The document number is A22163-0-MTR150DCSVV UMA SATA.
Q: What is the board number and revision for this motherboard?
A: The board number is CSD502AX1000, revision A01.
A: The embedded controller is a KBC1070.
Q: What charging IC and architecture does this board use?
A: The charging IC is a BQ24703.
Q: What is the memory architecture on this board?
A: The board supports two DDR2 SODIMM slots.
| Brand | Inventec |
| Model | Vulcain UMA |
| Project Code | Vulcain UMA |
| Board Number | CSD502AX1000 |
| Revision | A01 |
| Date | 26-Dec-2008 |
| CPU Platform | Penryn |
| GPU Type | UMA |
| Graphics Architecture | 965GM |
| EC / KBC | KBC1070 |
| Audio Codec | ALCOR AU6433 |
| BIOS / SPI Flash | System BIOS |
| Charging IC | BQ24703 |
| Charger Architecture | BQ24703 |
| Power IC(s) | TPS51120, APL5913, TPS51117, ADP3208, TPS51124, G2997 |
| RAM Type | DDR2 |
| RAM Architecture | DDR2_SODIMM0, DDR2_SODIMM1 |
| Card Reader IC | ALCOR AU6433 |
| LAN IC | Marvell |
| WiFi / WLAN IC | Mini Card |
| Document Number | A22163-0-MTR150DCSVV UMA SATA |
