hp 500_510 compal_la-3361p_rev1.0 schematic
hp 500_510=1=compal_la-3361p_rev1.0.pdf
This Compal LA-3361P Rev 0.3 motherboard schematic, dated September 21, 2006, documents a platform built around the Mobile Dothan/Yonah uFCPGA-478 CPU with Intel Alviso GMCH (915GM/910GML) graphics and ICH6-M southbridge core logic. The system memory architecture is DDR2 SO-DIMM across two slots. The embedded controller is a KB910L, and the audio subsystem is handled by a Conexant CX20468-31 codec paired with a TPA6211 amplifier. The BIOS/SPI flash is an SST39VF080-70 parallel flash ROM. The charging IC is a BQ24703, and the LAN controller is an Intel 82562V 10/100. Thermal monitoring is provided by an ADM1032 sensor, and the clock generation is managed by an ICS 954226. The platform supports Mini PCI for wireless connectivity and includes a CardBus controller (CB-1410) and a modem (AMOM EC KB910L).
Q: What BIOS flash IC is used on this motherboard?
A: The BIOS/SPI flash is an SST39VF080-70 parallel flash ROM.
A: The embedded controller is a KB910L.
A: The memory architecture is DDR2 SO-DIMM across two slots.
A: The charging IC is a BQ24703.
A: The audio codec is a Conexant CX20468-31, and the audio amplifier is a TPA6211.
| Document Number | LA-3361P |
| Revision | 0.3 |
| Date | Thursday, September 21, 2006 |
| CPU Platform | Mobile Dothan uFCPGA with Intel Alviso_GM+ICH6-M core logic |
| CPU Socket | uFCPGA-478 |
| PCH / Southbridge | Intel ICH6-M |
| GPU Type | Intel Alviso GMCH |
| Graphics Architecture | Alviso 915GM / 910GML |
| EC / KBC | KB910L |
| Audio Codec | Conexant CX20468-31 |
| BIOS / SPI Flash | SST39VF080-70 |
| Charging IC | BQ24703 |
| RAM Type | DDR2 |
| Thermal Sensor | ADM1032 |
| LAN IC | 82562V 10/100 |
| WiFi / WLAN IC | Mini PCI |
| Audio Amplifier | TPA6211 |
| Clock Generator | ICS 954226 |
| Flash ROM | SST39VF080-70 |
Dothan
ICH6
Alviso (915GM, 910GML)
KB910L
CX20468-31
SST39VF080-70
BQ24703
ADM1032
82562V 10/100
TPA6211
ICS954226
Dothan
ICH6
KB910L
CX20468-31
SST39VF080-70
BQ24703
ADM1032
82562V 10/100
TPA6211
ICS954226
