HP 2000 6050A2498701-MB-A02 AMD Schematic
This Inventec Sarah 15.6 Brazos motherboard, board number 1310A24127-0-MTR revision A3, is built on the AMD Brazos 2.0 platform featuring an AMD Zacate APU paired with a Hudson M3 M3L FCH. The system memory architecture consists of two DDR3 SO-DIMM slots. The embedded controller is an ITE8517, and the audio subsystem is managed by an ALC3201 codec. The BIOS is stored on an SPI ROM. Power management is handled by a multi-rail design utilizing TPS51218, TPS51216, TPS51511, TPS51317, TPS54319RTE, TPS51123, and TPS5137 regulators, with battery charging controlled by a BQ24726 IC. Networking is provided by dual LAN options: a Realtek RTL8165EH for 10/100 and an RTL8161FH for Gigabit Ethernet. A Realtek RTS5219-GR card reader is integrated for SD card support.
Q: What is the board number and revision for this Inventec motherboard?
A: The board number is 1310A24127-0-MTR, revision A3.
A: The embedded controller is an ITE8517.
Q: What is the charging IC and charger architecture?
A: The charging IC is a BQ24726, and the charger architecture uses Adapter I_ADP.
Q: What LAN IC options are available on this motherboard?
A: Two LAN options are documented: a Realtek RTL8165EH for 10/100 LDO mode and a Realtek RTL8161FH for Gigabit switch mode.
| Brand | Inventec |
| Model | Sarah 15.6 Brazos |
| Project Code | Brazos |
| Board Number | 1310A24127-0-MTR |
| Revision | A3 |
| Date | 2011/11/02 |
| CPU Platform | AMD Brazos 2.0 |
| PCH / Southbridge | Hudson M3 M3L |
| GPU Type | AMD Zacate |
| EC / KBC | ITE8517 |
| Audio Codec | ALC3201 |
| Charging IC | BQ24726 |
| Charger Architecture | Adapter I_ADP |
| Power IC(s) | TPS51218, TPS51216, TPS51511, TPS51317, TPS54319RTE, TPS51123, TPS5137 |
| Card Reader IC | Realtek RTS5219-GR |
| LAN IC | RTL8165EH (10/100) LDO MODE, RTL8161FH (GIGA-LAN) SWITCH MODE |
| WiFi / WLAN IC | Realtek |
1310A24127-0-MTR
Brazos
HUDSON M3 M3L
AMD Zacate
IT8517
ALC3201
BQ24726
TPS51123
TPS51216
TPS51218
TPS51317
TPS5137
TPS51511
TPS54319RTE
RTS5219-GR
RTL8161FH SWITCH MODE
RTL8165EH LDO MODE
1310A24127-0-MTR
Brazos
HUDSON M3 M3L
AMD Zacate
IT8517
ALC3201
BQ24726
TPS51123
TPS51216
TPS51218
TPS51317
TPS5137
TPS51511
TPS54319RTE
RTS5219-GR
RTL8165EH LDO MODE
