Schematic hp 15-g021sr zso51 compal la-a996p rev4.0 schematic
hp 15-g021sr zso51_compal la-a996p_rev4.0 schematic
hp 15-g021sr=1=zso51_compal la-a996p_rev4.0.pdf
BrandAMD
Motherboard ManufacturerCompal Electronics, Inc.
Project CodeZSO51
Board NumberLA-A996P
Revision0.1
Date2014/02/08
CPU PlatformAMD APU Beema/Kabini FT3
GPU TypeATI SUN LE
Graphics ArchitectureATI SUN LE BGA 631-balls
EC / KBCENE KBC9012
Audio CodecAudio ALC3227
BIOS / SPI FlashBIOS (4MByte)
RAM TypeDDR3L
RAM ArchitectureSingle Channel
RAM Quantity / Slots204pin DDR3L-SO-DIMM
Card Reader ICRTS5239
LAN ICRTL8166
WiFi / WLAN ICWLANBT Combo
This Compal LA-A996P motherboard, project code ZSO51, is built around an AMD APU Beema/Kabini FT3 platform with integrated Yangtze FCH. The graphics subsystem is an ATI SUN LE GPU in a BGA 631-ball package, supported by four DDR3 1G VRAM chips. System memory is provided via a single 204-pin DDR3L SO-DIMM slot operating in single-channel mode. The embedded controller is an ENE KBC9012, and the audio codec is an ALC3227. The BIOS is stored on a 4MByte SPI flash ROM. Networking is handled by a Realtek RTL8166 10/100 LAN controller with an integrated transformer and RJ45 connector, while wireless connectivity uses a WLANBT Combo module. A Realtek RTS5239 card reader is also present.
A: The board number is LA-A996P, and the project code is ZSO51.
A: The embedded controller is an ENE KBC9012.
Q: What is the BIOS flash capacity on this motherboard?
A: The BIOS flash is a 4MByte SPI ROM.
A: The memory architecture is single-channel DDR3L, using a single 204-pin SO-DIMM slot.
  • HP 15-g021sr=1=ZSO51_Compal LA-A996P_Rev4.0.zip
