hp 15-g021sr zso51_compal la-a996p_rev4.0 schematic
hp 15-g021sr=1=zso51_compal la-a996p_rev4.0.pdf
This Compal LA-A996P motherboard, project code ZSO51, is built around an AMD APU Beema/Kabini FT3 platform with integrated Yangtze FCH. The graphics subsystem is an ATI SUN LE GPU in a BGA 631-ball package, supported by four DDR3 1G VRAM chips. System memory is provided via a single 204-pin DDR3L SO-DIMM slot operating in single-channel mode. The embedded controller is an ENE KBC9012, and the audio codec is an ALC3227. The BIOS is stored on a 4MByte SPI flash ROM. Networking is handled by a Realtek RTL8166 10/100 LAN controller with an integrated transformer and RJ45 connector, while wireless connectivity uses a WLANBT Combo module. A Realtek RTS5239 card reader is also present.
A: The board number is LA-A996P, and the project code is ZSO51.
A: The embedded controller is an ENE KBC9012.
A: The BIOS flash is a 4MByte SPI ROM.
A: The memory architecture is single-channel DDR3L, using a single 204-pin SO-DIMM slot.
| Brand | AMD |
| Project Code | ZSO51 |
| Board Number | LA-A996P |
| Revision | 0.1 |
| Date | 2014/02/08 |
| CPU Platform | AMD APU Beema/Kabini FT3 |
| GPU Type | ATI SUN LE |
| Graphics Architecture | ATI SUN LE BGA 631-balls |
| EC / KBC | ENE KBC9012 |
| Audio Codec | Audio ALC3227 |
| BIOS / SPI Flash | BIOS (4MByte) |
| RAM Type | DDR3L |
| RAM Quantity / Slots | 204pin DDR3L-SO-DIMM |
| Card Reader IC | RTS5239 |
| LAN IC | RTL8166 |
| WiFi / WLAN IC | WLANBT Combo |
