Schematic hasee hp500 hp520 quanta sw7 rev1a schematic
hasee hp500 hp520 quanta sw7_rev1a schematic
hasee hp500 hp520=1=quanta sw7_rev1a.pdf
BrandQuanta Computer Inc.
Project CodeSW7
DateFriday, September 28, 2007
CPU PlatformMerom 479P (uPGA)/46W
NorthbridgeCrestline
SouthbridgeICH-8M
Clock GeneratorICS9LPRS365AGLFT
Clock Generator Reference DesignatorU24
EC / KBCKB3926
Charging ICMAX8724
System Power ICMAX8778
CPU Core Power ICMAX8771
VGA Core Power ICMAX1992
DDR_VTERM RegulatorTPS51116REGR
VCCP +1.5V and GMCH 1.05V Power ICMAX8717
LAN ICMARVELL 8055/8039
Card Reader ICPCI7402
RAM TypeDDR II
RAM Architecture533/667 MHz DDR II
RAM Quantity / SlotsDDR2-SODIMM1, DDR2-SODIMM2
Crystal Frequency (Clock Gen)14.318MHz
Crystal Reference Designator (Clock Gen)Y9
The Quanta SW7 project motherboard is built around an Intel Merom 479P (uPGA)/46W CPU platform with a Crestline Northbridge and ICH-8M Southbridge. System clock generation is handled by an ICS9LPRS365AGLFT clock generator at reference designator U24, driven by a 14.318MHz crystal at Y9. The embedded controller is a KB3926. Power management includes a MAX8778 system power IC, a MAX8771 CPU core regulator, a MAX1992 VGA core regulator, a MAX8724 system charger, a TPS51116REGR DDR_VTERM regulator, and a MAX8717 for VCCP +1.5V and GMCH 1.05V. Memory configuration supports two DDR2-SODIMM slots running at 533/667 MHz. Networking is provided by a Marvell 8055/8039 LAN IC, and a PCI7402 controller manages the card reader interface.
Q: What is the project code and board manufacturer for this motherboard?
A: The project code is SW7, manufactured by Quanta Computer Inc.
A: The embedded controller is a KB3926.
Q: What is the clock generator IC and its reference designator?
A: The clock generator is an ICS9LPRS365AGLFT at reference designator U24.
A: The system charger IC is a MAX8724.
A: The LAN IC is a Marvell 8055/8039.
  • Hasee HP500 HP520=1=Quanta SW7_Rev1A.zip
