haier raytheon 911 quanta nl8e
The Quanta NL8E project, documented under number Custom167 revision 1A dated August 25, 2016, is built around the Intel SkyLake-H processor in a BGA1440 package. The platform utilizes an Intel SKL PCH-H Platform Controller Hub and supports discrete NVIDIA graphics based on the N17E-G1 architecture. System memory consists of two DDR4 SODIMM slots. The embedded controller is an IT8987, and the audio subsystem is handled by an ALC255 codec paired with an ALC1003-VB-CGT amplifier. The BIOS is stored on a 16MB SPI flash device. Networking is provided by a Realtek RTL8111H-CG LAN controller, and a Realtek RTS5227S manages the card reader. USB-C functionality is supported by a Cypress CYPD2122-24LQIT controller and a TUSB1046 redriver, while the ASM1142 serves as a USB hub controller. The charging IC is a TPS25462.
Q: What is the project code and document number for this motherboard?
A: The project code is NL8E, and the document number is Custom167, revision 1A, dated August 25, 2016.
A: The embedded controller is an IT8987.
A: The BIOS is stored on a 16MB SPI flash device.
Q: What is the discrete GPU configuration?
A: The discrete GPU is an NVIDIA chip based on the N17E-G1 architecture.
Q: What USB-C controller and redriver are used?
A: The USB-C controller is a Cypress CYPD2122-24LQIT, and the redriver is a TUSB1046.
| Project Code | NL8E |
| Document Number | Custom167 |
| Revision | 1A |
| Date | Thursday, August 25, 2016 |
| CPU Platform | SkyLake-H |
| CPU Model | Processor : Quad Core |
| CPU Socket | BGA1440 |
| PCH / Southbridge | Intel SKL PCH-H Platform Controller Hub |
| GPU Type | NVIDIA GPU |
| Graphics Architecture | N17E-G1 |
| EC / KBC | IT8987 |
| Audio Codec | ALC255 |
| Audio Amplifier | ALC1003-VB-CGT |
| BIOS / SPI Flash | SPI Flash (16MB) |
| Charging IC | TPS25462 |
| Card Reader IC | RTS5227S |
| USB Hub IC | ASM1142 |
| LAN IC | RTL8111H-CG |
| USB-C Controller | CYPD2122-24LQIT |
| USB-C Redriver | TUSB1046 |
NL8E
Skylake-H
Nvidia-GPU
N17E-G1
IT8987
ALC255
ALC1003-VB-CGT
Audio Amplifier
TPS25462
RTS5227S
ASM1142
RTL8111H_CG
CYPD2122-24LQIT
NL8E
Skylake-H
Nvidia-GPU
N17E-G1
IT8987
ALC255
ALC1003-VB-CGT
Audio Amplifier
TPS25462
RTS5227S
ASM1142
RTL8111H_CG
CYPD2122-24LQIT
