Gigabyte B550M DS3H Rev 1.0 1.01 Schematic
The Gigabyte B550M DS3H motherboard, revision 1.0, is built on the AMD AM4 platform with a Promontory PCH. The board utilizes an IT5702 EC/KBC and an IT8688E thermal sensor. Audio is handled by the ALC1220 HD audio codec, while networking is provided by the RTL8111G LAN IC and an M2_WIFI slot. The system supports four unbuffered DDR4 DIMM slots. Power management is managed by a combination of IR35201 and IR3555 VR controllers, along with RT8120D, NCT3103S, and RT8068A power ICs. The board includes an RTS5441 card reader and an IT5702 HDMI level shifter. The SPI BIOS flash is used for system firmware storage.
A: The motherboard uses an IT5702 EC/KBC.
Q: What audio codec is featured on this board?
A: The board features the ALC1220 HD audio codec.
A: The board uses the RTL8111G LAN IC.
Q: What power management ICs are present?
A: The board uses IR35201 and IR3555 for VR control, along with RT8120D, NCT3103S, and RT8068A for other power rails.
The Gigabyte B550M DS3H motherboard, revision 1.01, is built around the AMD AM4 platform with a Promontory chipset. It features four unbuffered DDR4 memory slots and utilizes a Realtek ALC887 HD audio codec alongside an RTL8111G LAN controller. The system is managed by an IT5702 EC/KBC and an IT8688E Super I/O. Power regulation is handled by an RAA229004 PWM controller, with additional power ICs including the RT8120D, NCT3103S, and RT8068A. A Realtek RTS5441 card reader IC is present, and the board supports M.2 WiFi connectivity. The schematic document is dated May 7, 2020.
A: The EC/KBC is an IT5702.
Q: What audio codec is used on the B550M DS3H?
A: The audio codec is a Realtek ALC887.
Q: What LAN controller is present on this board?
A: The LAN controller is an RTL8111G.
A: The board supports unbuffered DDR4 memory across four DIMM slots.
| Brand | Gigabyte |
| Model | B550M DS3H |
| Motherboard Manufacturer | Gigabyte |
| Document Number | B550M DS3H |
| Date | Wednesday, April 22, 2020 |
| CPU Platform | AMD AM4 |
| PCH / Southbridge | Promontory |
| EC / KBC | IT5702 |
| Audio Codec | ALC1220 |
| BIOS / SPI Flash | SPI BIOS |
| RAM Architecture | UNBUFFERED |
| RAM Quantity / Slots | 4 |
| LAN IC | RTL8111G |
| WiFi / WLAN IC | M2_WIFI |
| Charging IC | RT8120D |
| Power IC(s) | IR35201, IR3555, RT8120D, NCT3103S, RT8068A |
| Thermal Sensor | IT8688E |
| Card Reader IC | RTS5441 |
| USB Hub IC | USB31 Hub |
| HDMI Level Shifter | IT5702 |
| Brand | Gigabyte |
| Revision | 1.01 |
| Date | Thursday, May 07, 2020 |
| LAN IC | RTL8111G |
| EC / KBC | IT5702 |
| Super I/O | IT8688E |
| PWM Controller | RAA229004 |
| RAM Architecture | Unbuffered |
| Power IC(s) | NCT3103S, RT8068A |
AM4
IT5702
ALC1220
RTL8111G
M2_WIFI
RT8120D
IR35201
IR3555
NCT3103S
RT8068A
RT8120D
IT8688E
RTS5441
USB31 HUB
IT5702
ALC887
IT8688E
Super I/O
RAA229004
AM4
IT5702
ALC1220
RTL8111G
M2_WIFI
RT8120D
IR35201
IR3555
NCT3103S
RT8068A
RT8120D
IT8688E
RTS5441
USB31 HUB
IT5702
ALC887
IT8688E
Super I/O
RAA229004
