Gigabyte B550M DS3H AC Rev 1.0 1.1 Schematic
The Gigabyte B550M DS3H AC motherboard, revision 1.0, is built on the AMD AM4 platform with a Promontory PCH. It features four unbuffered DDR4 memory slots. The system is managed by an ITE IT8688E EC/KBC, while audio is handled by a Realtek ALC887 codec. Networking is provided by a Realtek RTL8111G LAN IC. Power regulation is managed by an IR35201 controller paired with IR3555 power stages, alongside RT8120, NCT3103S, and RT8068A power ICs. The board includes an M2_WIFI slot for wireless connectivity, a Realtek RTS5441 card reader, and a VL53 USB hub IC.
A: The ITE IT8688E LPC SIO is used.
A: The Realtek ALC887 HD Audio codec is used.
A: The Realtek RTL8111G LAN IC is used.
A: The board supports unbuffered DDR4 memory across four DIMM slots.
This Gigabyte B550M DS3H AC motherboard, revision 1.1, is built on the AMD AM4 platform with a Promontory chipset. The system memory architecture consists of four unbuffered DDR4 DIMM slots. Audio processing is handled by a Realtek ALC1220 High Definition Audio Codec, while network connectivity is provided by a Realtek RTL8111G LAN IC. The embedded controller is an ITE IT8688E LPC Super I/O. Power regulation is managed by an IR35201 controller paired with IR3555 MOSFETs for VCORE/VCORE_SOC, alongside RT8120, NCT3103S, and RT8068A for memory power rails. The board includes an M2_WIFI slot for wireless connectivity.
Q: What is the board number and revision of this Gigabyte motherboard?
A: The document number is B550M DS3H AC, revision 1.1.
A: The embedded controller is an ITE IT8688E LPC Super I/O.
A: The audio codec is a Realtek ALC1220 High Definition Audio Codec.
A: The LAN IC is a Realtek RTL8111G.
| Brand | Gigabyte |
| Model | B550M DS3H AC |
| Motherboard Manufacturer | Gigabyte |
| Document Number | B550M DS3H AC |
| Date | Monday, July 20, 2020 |
| CPU Platform | AMD AM4 |
| PCH / Southbridge | Promontory |
| EC / KBC | ITE IT8688E |
| LAN IC | Realtek RTL8111G |
| RAM Architecture | Unbuffered |
| RAM Quantity / Slots | 4 |
| Charging IC | IR35201 |
| Power IC(s) | IR35201 + IR3555, RT8120, NCT3103S, RT8068A |
| WiFi / WLAN IC | M2_WIFI |
| Card Reader IC | RTS5441 |
| USB Hub IC | VL53 |
| Brand | Gigabyte |
| Revision | 1.1 |
| Date | Friday, September 04, 2020 |
| Audio Codec | Realtek ALC1220 |
