fujitsu siemens esprimo v5505 c45 c46 rev -1
This Wistron C45/C46 motherboard, dated April 24, 2007, with PCB number 06254 revision -1, is designed for the Mobile CPU Merom 479 platform. The platform utilizes an ICH8M southbridge and features an ATI M71/M72 discrete GPU. System memory is DDR2 operating at 533/667 MHz. The embedded controller is a Winbond WPC8763L, and the audio codec is a CX20549. Power management is handled by a combination of ICs including the MAX8725 charger, TPS51120, SC411, APL5915, TPS5110, and ISL6262. Networking is provided by a Realtek RTL8111B Gigabit LAN controller, and wireless connectivity supports 802.11a/b/g/n standards. A Realtek RTS5158 card reader and a Genesys GL850G USB hub are also integrated. The BIOS is accessed via a Serial Peripheral Interface (SPI).
A: The PCB number is 06254. The project codes are 91.4U501.001 for C45 and 91.4V001.001 for C46.
A: The embedded controller is a Winbond WPC8763L.
A: The charging IC is a MAX8725.
Q: What is the CPU and PCH platform for this motherboard?
A: The CPU platform is a Mobile CPU Merom 479, and the PCH is an ICH8M.
| Project Code | C45 Project code: 91.4U501.001 / C46 Project code: 91.4V001.001 |
| Board Number | PCB Number : 06254 |
| Revision | -1 |
| Date | Tuesday, April 24, 2007 |
| CPU Platform | Mobile CPU Merom 479 2G/2.33G |
| PCH / Southbridge | ICH8M |
| GPU Type | ATI M71/M72 |
| EC / KBC | Winbond WPC8763L |
| Audio Codec | CX20549 |
| BIOS / SPI Flash | SPI I/F |
| Charging IC | MAX8725 |
| Power IC(s) | TPS51120 / SC411 / APL5915 / TPS5110 / ISL6262 |
| RAM Type | DDR2 533/667 MHz |
| RAM Architecture | DDR Memory I/F |
| LAN IC | RTL8111B |
| WiFi / WLAN IC | 802.11/a/b/g/n |
| Card Reader IC | RTS5158 |
| USB Hub IC | GL850G |
91.4U501.001
91.4V001.001
C45
C46
PCB NUMBER : 06254
233G
Merom
ICH8M
M71
M72
WPC8763L
CX20549
MAX8725
APL5915
ISL6262
SC411
TPS5110
TPS51120
RTL8111B
RTS5158
GL850G
91.4U501.001
91.4V001.001
C45
C46
PCB NUMBER : 06254
233G
Merom
ICH8M
M71
M72
WPC8763L
CX20549
MAX8725
APL5915
ISL6262
SC411
TPS5110
TPS51120
RTL8111B
RTS5158
GL850G
