DELL XPS 9360 LA-D841P Schematic
This Dell/Compal LA-D841P Rev 1.0 (A00) motherboard, project code Dino2 MLK, is built around the Intel Kaby Lake ULT platform. The system memory architecture is dual-channel 1.2V LPDDR3 running at 1866 MHz in a non-interleave configuration. The embedded controller is an ECM 5085, and the audio subsystem is handled by a Realtek ALC3246 codec. The SPI flash for BIOS is specified as 128/256Mb. A Realtek RTS5242D card reader controller is integrated, and wireless connectivity includes Bluetooth 4.0. The board was dated 2016-06-21.
A: The board number is LA-D841P, revision 1.0 (A00).
A: The embedded controller is an ECM 5085.
A: The memory architecture is dual-channel 1.2V LPDDR3 at 1866 MHz in a non-interleave configuration.
A: The audio codec is a Realtek ALC3246.
| Brand | Dell |
| Motherboard Manufacturer | Compal |
| Project Code | Dino2 MLK (Kaby Lake ULT) |
| Board Number | LA-D841P |
| Revision | 1.0 (A00) |
| Date | 2016-06-21 |
| CPU Platform | Kaby Lake ULT |
| EC / KBC | ECM 5085 |
| Audio Codec | ALC3246 |
| BIOS / SPI Flash | 128/256Mb |
| RAM Type | LPDDR3 |
| RAM Architecture | Dual Channel 1.2V LPDDR3 1866 MHz Non-Interleave |
| Card Reader IC | RTS5242D |
| WiFi / WLAN IC | BT4.0 |
