Dell Wistron Selek G5 AMD 19802-1 Schematic
This Wistron Selek MLK G5 AMD motherboard, project code 4PD0K5010001 and board number 19802 revision X02, is built around the AMD Renoir APU platform. The discrete graphics solution is provided by a Navi 10 XTM R19M-E120-70 GPU with 6GB GDDR6 VRAM. System memory consists of two DDR4 SODIMM slots supporting dual-channel 3200MHz operation. The embedded controller is a Nuvoton NPCE386, and the audio codec is an ALC3254. The BIOS is stored on a 16MB Quad Read SPI flash. Connectivity includes a Realtek RTL8111H Gigabit LAN controller, a GENESYS GL852G USB hub, a RTS5144 SD card reader, and a Parade PS8409A HDMI 2.0 re-driver. The board also features a CYPRESS CYPD4126 USB-C controller and a TITUSB1044 re-driver for DP 1.4 and USB 3.1 Gen 2.
Q: What is the EC/KBC used on this motherboard?
A: The embedded controller is a Nuvoton NPCE386.
A: The BIOS is stored on a 16MB Quad Read SPI flash.
Q: What is the discrete GPU configuration?
A: The discrete GPU is a Navi 10 XTM R19M-E120-70 with 6GB GDDR6 VRAM.
A: The board supports two DDR4 SODIMM slots for dual-channel 3200MHz memory.
| Model | Selek MLK G5 AMD |
| Project Code | 4PD0K5010001 |
| Board Number | 19802 |
| Revision | X02 |
| Date | 2019-12-16 |
| CPU Platform | Renoir |
| GPU Type | Navi 10 XTM R19M-E120-70 |
| Graphics Architecture | GDDR6 |
| EC / KBC | Nuvoton NPCE386 |
| Audio Codec | ALC3254 |
| BIOS / SPI Flash | 16MB Quad Read |
| RAM Architecture | SODIMM A, SODIMM B |
| Card Reader IC | RTS5144 |
| USB Hub IC | GENESYS GL852G |
| LAN IC | RTL8111H |
| WiFi / WLAN IC | 6380 2.11AC/AX M.2 WLAN |
| HDMI Level Shifter | Parade PS8409A |
4PD0K5010001
19802
Renoir
GDDR6
NPCE386
ALC3254
RTS5144
GL852G
RTL8111H
PS8409A
4PD0K5010001
19802
Renoir
GDDR6
NPCE386
ALC3254
RTS5144
GL852G
RTL8111H
PS8409A
