Dell Wistron Odin_Antman AMD 203131 Schematic
The Wistron Odin/Antman AMD motherboard, project code QRQY00001095 with PCB P/N 203131 revision SA, is built around the Barcelo AMD APU platform in a BGA-1140 pin package supporting R3/R5/R7 processors. Graphics are handled by an NVIDIA GN18-S5 GPU with 2GB GDDR6 VRAM, with board configuration supporting either UMA-only or discrete Optimus graphics. The system uses DDR4 3200MHz memory across two SODIMM slots in dual-channel architecture. The embedded controller is a Nuvoton NPCE48AL with LPC debug port and SPI programming capability. The BIOS flash is a 16MB Quad Read SPI ROM. The charging IC is an NPCT750JAAYX. Audio is provided by a Realtek ALC3254 codec. Networking includes a Realtek RTL8111H LAN controller and NGFF WLAN/BT module. The card reader is a Realtek RTS5144, and the USB hub controller is a GENESYS GL835. HDMI level shifting is handled by a Parade PS8719.
Q: What is the BIOS flash capacity and type on this motherboard?
A: The BIOS flash is a 16MB Quad Read SPI ROM.
A: Yes, the Nuvoton NPCE48AL EC/KBC supports programming via the LPC debug port and SPI interface.
A: Yes, the board supports both UMA-only and discrete Optimus configurations, as indicated by the OPS: DISCRTE OPTIMUS installed and UMA: UMA only installed options.
A: The charging IC is an NPCT750JAAYX.
| Model | Odin/Antman AMD |
| Project Code | QRQY00001095 |
| Board Number | 203131 |
| Revision | SA |
| Date | Friday, June 11, 2021 |
| CPU Platform | Barcelo AMD APU 25W BGA-1140pin R3/R5/R7 |
| GPU Type | NVIDIA GN18-S5 25W |
| Graphics Architecture | GDDR6 2GB |
| dGPU to UMA Conversion Support | UMA: UMA only installed / OPS: DISCRTE OPTIMUS installed |
| EC / KBC | Nuvoton NPCE48AL |
| EC/KBC Programmable | LPC debug port / KBC FAN PS2 Fan Control / SPI |
| Audio Codec | Realtek ALC3254 |
| BIOS / SPI Flash | 16MB Quad Read |
| BIOS Flash Capacity | 16MB |
| Charging IC | NPCT750JAAYX |
| RAM Type | DDR4 3200MHz |
| RAM Architecture | Channel A / Channel B |
| RAM Quantity / Slots | SODIMM A / SODIMM B |
| Card Reader IC | Realtek RTS5144 |
| USB Hub IC | GENESYS GL835 |
| LAN IC | Realtek RTL8111H |
| WiFi / WLAN IC | NGFF WLAN BT |
| HDMI Level Shifter | Parade PS8719 |
QRQY00001095
203131
Barcelo
R5
R7
GN18-S5 25W
GDDR6 2GB
NPCE48AL
ALC3254
NPCT750JAAYX
RTS5144
GL835
RTL8111H
PS8719
QRQY00001095
203131
Barcelo
R5
R7
GN18-S5 25W
GDDR6 2GB
NPCE48AL
ALC3254
NPCT750JAAYX
RTS5144
GL835
RTL8111H
PS8719
