Dell Wistron Odin 13 NV ADL X01 203127 Schematic
The Wistron Odin 13 N/V motherboard, project code 4PD0Q50100 and board number A41105 revision X01, is built around the Alder Lake P platform with integrated UMA graphics and no discrete GPU installed. The system utilizes onboard LPDDR5 memory and a 32MB BIOS ROM. The embedded controller is a NUVOTON NCT7718W communicating via eSPI, while audio is handled by a REALTEK ALC3204 codec. Charging is managed by a BQ25721RSNR IC. The board features a MICROCHIP LAN controller, CNVi 2.0 wireless connectivity, a Burnside BRIDGE HDMI level shifter, a GL9755 card reader, and a CYPD6228 USB hub controller. Thermal sensing is provided by an ST LIS2DW12TR sensor.
A: The EC/KBC is a NUVOTON NCT7718W, programmable via eSPI.
A: The charging IC is a BQ25721RSNR.
Q: What type of memory architecture does this motherboard use?
A: This motherboard uses onboard LPDDR5 memory.
A: The audio codec is a REALTEK ALC3204.
| Model | Odin 13 N/V |
| Project Code | 4PD0Q50100 |
| Board Number | A41105 |
| Revision | X01 |
| Date | Friday, August 06, 2021 |
| CPU Platform | Alder Lake P |
| Platform Alias | Odin ADL-P |
| GPU Type | UMA: Unified Memory Architecture |
| Graphics Architecture | N/VDY : None Installed |
| EC / KBC | NUVOTON NCT7718W |
| EC/KBC Programmable | eSPI |
| Audio Codec | REALTEK ALC3204 |
| BIOS / SPI Flash | 32MB |
| Charging IC | BQ25721RSNR |
| RAM Type | LPDDR5 |
| RAM Architecture | Onboard |
| LAN IC | MICROCHIP |
| WiFi / WLAN IC | CNVi 2.0 |
| HDMI Level Shifter | Burnside BRIDGE |
| Card Reader IC | GL9755 |
| USB Hub IC | CYPD6228 |
| Thermal Sensor | ST LIS2DW12TR |
4PD0Q50100
A41105
Alder Lake-P
NCT7718W
ALC3204
BQ25721RSNR
LPDDR5
CNVi 2.0
GL9755
CYPD6228
ST LIS2DW12TR
4PD0Q50100
A41105
Alder Lake-P
NCT7718W
ALC3204
BQ25721RSNR
LPDDR5
CNVi 2.0
GL9755
CYPD6228
ST LIS2DW12TR
