Schematic dell vostro 3400 wistron winery calpella n11m-ge revx01 schematic
dell vostro 3400 wistron winery calpella n11m-ge_revx01 schematic
dell vostro 3400=1=wistron winery calpella n11m-ge_revx01.pdf
BrandDell
ModelVostro
Motherboard ManufacturerWistron Corporation
Project Code91.4ES01.001
Board Number48.4ES11.0SB
RevisionSAVTT_CORE
DateMonday, January 18, 2010
CPU PlatformIntel Arrandale
PCH / SouthbridgeIntel Ibex Peak-M
GPU TypeNvidia N11M-GE ([URL="https://dr-bios.com/components/graphics-models/40nm/"]40nm)[/URL]
Graphics ArchitectureUMA / DIS
EC / KBCNUVOTON NPCE781BA0DX
EC/KBC PackageLPC Bus
Audio CodecIDT 92HD81
BIOS / SPI Flash256kB Flash ROM
Charging ICBQ24745
Charger Architecture+PBATT / Adapter
Power IC(s)ISL62883, TPS51125, TPS51116, TPS51218, ADP3211, APL5930, RT9025
RAM TypeDDRIII 1066
RAM ArchitectureChannel A, Channel B
RAM Quantity / SlotsSlot 0, Slot 1
Card Reader ICRealtek RTS5138
LAN ICRTL8111DL
WiFi / WLAN IC802.11a/b/g/n
Thermal SensorEMC2102KBC
USB Hub ICTPS2231R
Document NumberX01
PCB P/N09297
This Dell Vostro Calpella motherboard, manufactured by Wistron Corporation under project code 91.4ES01.001 and board number 48.4ES11.0SB, is built around the Intel Arrandale CPU platform paired with the Intel Ibex Peak-M PCH. The graphics subsystem supports both UMA and DIS configurations, with the discrete option utilizing an Nvidia N11M-GE (40nm) GPU. System management is handled by a NUVOTON NPCE781BA0DX EC/KBC communicating via the LPC bus. The BIOS is stored in a 256kB Flash ROM. Audio is provided by an IDT 92HD81 codec. Power management is orchestrated by a BQ24745 charger IC, with multiple DC/DC converters including ISL62883, TPS51125, TPS51116, TPS51218, ADP3211, APL5930, and RT9025. Memory configuration consists of two DDRIII 1066 slots across Channel A and Channel B. The board integrates a Realtek RTS5138 card reader, an RTL8111DL LAN controller, and an EMC2102KBC thermal sensor.
A: The motherboard uses a NUVOTON NPCE781BA0DX EC/KBC communicating via the LPC bus.
Q: What BIOS flash configuration is present?
A: The BIOS is stored in a 256kB Flash ROM.
Q: Does this motherboard support both UMA and discrete graphics?
A: Yes, the schematic indicates support for both UMA and DIS (discrete) graphics configurations, with the discrete option using an Nvidia N11M-GE (40nm) GPU.
Q: What charging IC is used?
A: The charging IC is a BQ24745, supporting battery and adapter power paths.
  • Dell Vostro 3400=1=Wistron Winery Calpella N11M-GE_RevX01.zip
