dell m5010 berry dg15 amd x00 1012 3 1
This Wistron Berry AMD Discrete/UMA motherboard, board number A4192 revision X00, is built around the AMD Danube CPU platform (S1G4) with an AMD Champlain CPU and an AMD RS880M North Bridge paired with an AMD Madison-LP discrete GPU. The system uses DDRIII memory across two DIMM slots supporting 800/1066/1333 MHz. The embedded controller is a Nuvoton NPCE781BA0DXN in a UVOTON package. The BIOS is stored on a 2MB Flash ROM. Power management is handled by a BQ24745 charger IC and multiple regulators including ISL6265AHRTZ, RT8209EGQW, TPS51116RGER, TPS51117RGYR, RT9025, RT8208B, and TPS51125RGER. The audio codec is an IDT 92HD81B. Networking is provided by a Realtek RTL8103T LAN IC, and the card reader is a Realtek RTS5138. Thermal monitoring is managed by an EMC2102KBC sensor.
A: The EC/KBC is a Nuvoton NPCE781BA0DXN in a UVOTON package.
A: The BIOS is stored on a 2MB Flash ROM.
A: The charging IC is a BQ24745.
Q: What is the GPU configuration?
A: The motherboard uses an AMD RS880M North Bridge with integrated graphics and an AMD Madison-LP discrete GPU, supporting both Discrete and UMA graphics architectures.
| Model | Berry AMD Discrete/UMA |
| Project Code | Berry |
| Board Number | A4192 |
| Revision | X00 |
| Date | Monday, October 12, 2009 |
| CPU Platform | AMD Danube CPU S1G4 |
| CPU Model | AMD Champlain CPU S1G4 |
| GPU Type | AMD RS880M North Bridge / AMD Madison-LP |
| Graphics Architecture | Discrete/UMA |
| dGPU Chip Number | Madison-LP |
| EC / KBC | NPCE781BA0DXN |
| EC/KBC Package | UVOTON |
| Audio Codec | IDT 92HD81B |
| BIOS / SPI Flash | 2MB Flash ROM |
| Charging IC | BQ24745 |
| Charger Architecture | BQ24745 |
| Power IC(s) | ISL6265AHRTZ, RT8209EGQW, TPS51116RGER, TPS51117RGYR, RT9025, RT8208B, TPS51125RGER |
| RAM Architecture | 800/1066/1333 |
| Card Reader IC | Realtek RTS5138 |
| LAN IC | Realtek RTL8103T |
| WiFi / WLAN IC | WLAN&WWAN MiniCard x 2 |
| Thermal Sensor | EMC2102KBC |
A4192
Danube S1G4
Madison LP
Discrete / UMA
NPCE781BA0DXN
92HD81B
BQ24745
ISL6265AHRTZ
RT8208B
RT8209EGQW
RT9025
TPS51116RGER
TPS51117RGYR
TPS51125RGER
RTS5138
RTL8103T
EMC2102KBC
A4192
Danube S1G4
Madison LP
Discrete / UMA
NPCE781BA0DXN
92HD81B
BQ24745
ISL6265AHRTZ
RT8208B
RT8209EGQW
RT9025
TPS51116RGER
TPS51117RGYR
TPS51125RGER
RTS5138
RTL8103T
EMC2102KBC
