Dell Latitude E6530 LA-7762P Schematic
This Dell Dalmore 15 DS motherboard, manufactured by Compal Electronics, Inc., is built around the Ivy Bridge CPU platform paired with the Panther POINT-M PCH. The board number is LA-7762A ( DAZ0LI00100 ), with a document number of LA-7762P and a revision of 1.0 (A00). Graphics are handled by a discrete N13M-NS1 GPU. The system uses two DDRIII-DIMM slots for DDR3 memory. The embedded controller is an SMSC KBC MEC5055. Audio is provided by a 92HD93HDA Codec. The BIOS SPI flash configuration includes a Winbond W25Q32BVSSIG (64M) and a Winbond W25Q64CVSSIG (32M), both in SSIG packages. The charging IC is an ECE5048. Networking is supported by an Intel 82579LM Lewisville LAN IC and a BCM5882 WLAN IC. The HDMI level shifter is a PS8171, and the card reader controller is an XCOZ600FJ0.
A: The motherboard uses a Winbond W25Q32BVSSIG (64M) and a Winbond W25Q64CVSSIG (32M), both in SSIG packages.
A: The embedded controller is an SMSC KBC MEC5055.
A: The charging IC is an ECE5048.
Q: What is the HDMI level shifter on this motherboard?
A: The HDMI level shifter is a PS8171.
| Brand | Dell |
| Model | Dalmore 15 DS |
| Project Code | Dalmore 15 DS |
| Board Number | LA-7762A ( DAZ0LI00100 ) |
| Revision | 1.0 (A00) |
| Date | Wednesday, February 22, 2012 |
| Document Number | LA-7762P |
| CPU Platform | Ivy Bridge + Panther POINT |
| PCH / Southbridge | Panther POINT-M |
| GPU Type | N13M-NS1 |
| EC / KBC | SMSC KBC MEC5055 |
| Audio Codec | 92HD93HDA Codec |
| BIOS / SPI Flash | W25Q32BVSSIG, W25Q64CVSSIG |
| BIOS Flash Exact Model | W25Q32BVSSIG, W25Q64CVSSIG |
| BIOS Flash Manufacturer | Winbond |
| BIOS Flash Capacity | 64M, 32M |
| BIOS Flash Package | SSIG |
| Charging IC | ECE5048 |
| RAM Architecture | DDRIII-DIMM X2 |
| Card Reader IC | XCOZ600FJ0 |
| LAN IC | 82579LM Intel Lewisville |
| WiFi / WLAN IC | BCM5882 |
| HDMI Level Shifter | PS8171 |
Panther Point
N13M-NS1
MEC5055
92HD93HDA CODEC
W25Q32BVSSIG
W25Q64CVSSIG
ECE5048
XCOZ600FJ0
82579LM INTEL LEWISVILLE
BCM5882
PS8171
Panther Point
N13M-NS1
MEC5055
92HD93HDA CODEC
W25Q32BVSSIG
W25Q64CVSSIG
ECE5048
XCOZ600FJ0
BCM5882
PS8171
