dell latitude e5400 foose 14 mb 07236-1
The Wistron Foose Intel motherboard, project code 91.4X701.001 and board number 48.4X703.011, is built around the Intel Cantiga-GM chipset with an ICH9-M southbridge, supporting a uFCPGA Mobile Penryn CPU. The platform uses UMA graphics integrated into the Cantiga-GM. System memory consists of DDRII 667/800 across two slots configured as Channel A and Channel B. The embedded controller is an MEC5035 in a 3232 package. The BIOS is stored on a 16Mb SPI flash. Power management is handled by a TI charger architecture using a BQ24745 charging IC, with a multi-rail DC/DC system including ISL6260C, TPS51116, TPS51117, TPS5116, EMC4002, L6935TR, and SN0608098 regulators. Audio is provided by an IDT 92HD71B7 codec with a TPA6040/MAX9789A amplifier. Networking is supported by a BCM5761E or BCM5756M LAN IC. The clock generator is an ICS9LPR390, and the card reader is a Ricoh R5C847.
A: The motherboard uses a 16Mb SPI flash for BIOS storage.
A: The embedded controller is an MEC5035 in a 3232 package.
Q: What is the charging IC and charger architecture?
A: The charger architecture is TI CHARGER, using a BQ24745 charging IC.
A: The board supports DDRII
| Model | Foose Intel |
| Project Code | 91.4X701.001 |
| Board Number | 48.4X703.011 |
| PCB Number | 07236 |
| Revision | -1 |
| Date | 2008-06-05 |
| Document Number | A3158 |
| CPU Platform | Intel Cantiga-GM + ICH9M |
| CPU Model | uFCPGA Mobile Penryn |
| GPU Type | UMA |
| Graphics Architecture | Intel Cantiga-GM |
| EC / KBC | MEC5035 |
| EC/KBC Package | 3232 |
| Audio Codec | IDT 92HD71B7 |
| BIOS / SPI Flash | SPI FLASH 16Mb |
| BIOS Flash Capacity | 16Mb |
| Charging IC | BQ24745 |
| Charger Architecture | TI CHARGER |
| Power IC(s) | ISL6260C, TPS51116, TPS51117, TPS5116, EMC4002, L6935TR, SN0608098 |
| RAM Type | DDRII 667/800 |
| Card Reader IC | Ricoh R5C847 |
| LAN IC | BCM5761E / BCM5756M |
| WiFi / WLAN IC | SSM2602 |
| Clock Generator | ICS9LPR390 |
| Audio Amplifier | TPA6040/MAX9789A |
91.4X701.001
48.4X703.011
07236
Cantiga
ICH9
Intel Cantiga GM
MEC5035
92HD71B7
BQ24745
EMC4002
ISL6260C
L6935TR
SN0608098
TPS51116
TPS51117
TPS5116
RICOH R5C847
BCM5756M
BCM5761E
SSM2602
ICS9LPR390
MAX9789A
TPA6040
91.4X701.001
48.4X703.011
07236
Cantiga
ICH9
Intel Cantiga GM
MEC5035
92HD71B7
BQ24745
EMC4002
ISL6260C
L6935TR
SN0608098
TPS51116
TPS51117
TPS5116
RICOH R5C847
BCM5756M
BCM5761E
SSM2602
ICS9LPR390
MAX9789A
TPA6040
