dell la-d822p
This Dell Compal LA-D822P Rev 1.0 (A00) motherboard schematic, dated June 6, 2016, supports the Dali and Astro project codes with Skylake-U and Kabylake-U CPU platforms. The system utilizes an SMSC MEC1404-NU-GP EC/KBC and a W25Q128FVSIQ 16MB SPI flash ROM for BIOS storage. Audio is handled by a Realtek ALC3246-CG codec, while networking is provided by a Realtek RTL8111H LAN IC. The charging architecture is built around a CT7718W charging IC. Memory configuration consists of two DDR4 SODIMM slots supporting 1866/2133MHz. The board also features a Realtek RTS5170 card reader, an RTD2166 HDMI level shifter, and a TI TPS2544RTER USB hub IC for USB PowerShare functionality.
A: The BIOS SPI flash ROM is a W25Q128FVSIQ with a capacity of 16MB.
A: The embedded controller is an SMSC MEC1404-NU-GP.
A: The charging IC is a CT7718W.
A: The audio codec is a Realtek ALC3246-CG.
| Motherboard Manufacturer | Compal |
| Project Code | Dali & Astro |
| Board Number | LA-D822P |
| Revision | 1.0 (A00) |
| Date | Monday, June 06, 2016 |
| CPU Platform | Skylake-U / Kabylake-U |
| EC / KBC | SMSC MEC1404-NU-GP |
| BIOS Flash Exact Model | W25Q128FVSIQ |
| BIOS Flash Capacity | 16MB |
| Audio Codec | ALC3246-CG |
| Charging IC | CT7718W |
| LAN IC | Realtek RTL8111H |
| Card Reader IC | Realtek RTS5170 |
| WiFi / WLAN IC | 802.11b/g/n 802.11ac BT 4.0 1x1 |
| HDMI Level Shifter | RTD2166 |
| USB Hub IC | TI TPS2544RTER |
LA-D822P
Kaby Lake-U
Skylake-U
MEC1404-NU-GP
W25Q128FVSIQ
ALC3246-CG
CT7718W
RTL8111H
RTD2166
TPS2544RTER
LA-D822P
Kaby Lake-U
Skylake-U
MEC1404-NU-GP
W25Q128FVSIQ
ALC3246-CG
CT7718W
RTL8111H
RTD2166
TPS2544RTER
