Dell Inspiron 5505 Wistron Mockingbird AMD 19852-1 Schematic
The Wistron Mockingbird AMD motherboard, revision A00, dated 2020-04-24, is built around the AMD Renoir APU platform. It features a Nuvoton NPCE386 EC/KBC and a 16MB Quad Read SPI flash ROM for BIOS. The system supports DDR4 3200MHz memory across two SODIMM slots. Graphics are handled by a discrete GDDR5 R19M-P18-50 18W 2GB GPU with OPTIMUS support. Audio is managed by a Realtek ALC3204 codec, while networking includes a Realtek RTL8111H LAN controller and an NGFF WLAN module. The charging architecture utilizes a CYPRESS CYPD4126 controller under the CCG4 standard. Additional I/O includes a Realtek RTS5144 card reader and HDMI 1.4b output.
A: The motherboard uses a Nuvoton NPCE386 EC/KBC.
A: The BIOS is stored on a 16MB Quad Read SPI flash ROM.
A: The board supports DDR4 3200MHz memory via two SODIMM slots (SODIMM A and SODIMM B).
Q: What is the charging controller architecture?
A: The charging system uses a CYPRESS CYPD4126 controller under the CCG4 architecture.
| Model | Mockingbird AMD |
| Project Code | 19852X014PD0LW010001 |
| Board Number | MKB AMD |
| Revision | A00 |
| Date | 2020-04-24 |
| CPU Platform | Renoir |
| GPU Type | GDDR5 R19M-P18-50 18W 2GB |
| Graphics Architecture | OPS: DISCRTE OPTIMUS installed |
| EC / KBC | Nuvoton NPCE386 |
| Audio Codec | Realtek ALC3204 |
| BIOS / SPI Flash | Flash ROM 16MB Quad Read SPI |
| Charging IC | CYPRESS CYPD4126 |
| Charger Architecture | CCG4 |
| RAM Type | DDR4 3200MHz |
| RAM Architecture | SODIMM A, SODIMM B |
| Card Reader IC | Realtek RTS5144 |
| LAN IC | Realtek RTL8111H |
| WiFi / WLAN IC | 61 NGFF WLAN |
| HDMI Level Shifter | HDMI 1.4b |
| Document Number | A31106 |
