Dell Inspiron 3501 LA-K036P Schematic
This Compal-manufactured Dell Bullseye TGL motherboard, board number DA8001QB000 PCB 2X2 LA-K036P revision 1.0 (A00) dated 2021-03-08, is built on the TGL-U platform. The embedded controller is a MEC1515. The discrete GPU is an N17S-G3-A1 BGA 595P. The board supports multiple CPU options including Celeron FH8069004531901, Pentium FH8069004531802, Core i3 FH8069004531502, Core i5 FH8069004531301 and FH8069004530601, and Core i7 FH8069004529905 and FH8069004530104. The schematic explicitly notes that UMA configuration does not support an external graphics card.
A: The EC/KBC is a MEC1515.
Q: What GPU is used on this motherboard?
A: The discrete GPU is an N17S-G3-A1 BGA 595P.
A: No. The schematic explicitly states UMA@ does not support an external graphics card.
Q: What CPU models are supported on this motherboard?
A: Supported CPUs include Celeron FH8069004531901, Pentium FH8069004531802, Core i3 FH8069004531502, Core i5 FH8069004531301 and FH8069004530601, and Core i7 FH8069004529905 and FH8069004530104.
| Brand | Dell |
| Model | Bullseye TGL |
| Motherboard Manufacturer | Compal |
| Project Code | Bullseye TGL |
| Board Number | DA8001QB000 |
| PCB Number | da8001qb000-pcb-2x2-la-k036p/"]DA8001QB000 PCB 2X2 LA-K036P[/URL] |
| Revision | 1.0 (A00) |
| Date | 2021-03-08 |
| CPU Platform | TGL-U |
| EC / KBC | MEC1515 |
| GPU Type | N17S-G3 |
| dGPU Chip Number | N17S-G3-A1_BGA_595P |
| dGPU to UMA Conversion Support | UMA@ : not Support external Graphic card |
| CPU Model | FH8069004531901 QVBS B1 1.8G (Celeron), FH8069004531802 QVBK B1 2G (Pentium), FH8069004531502 QVBG B1 3G (i3), FH8069004531301 SRK05 B1 2.4G (i5), FH8069004529905 QVBA B1 2.8G (i7), FH8069004530601 QVBD B1 2.4G (i5), FH8069004530104 SRK02 B1 2.8G (i7) |
DA8001QB000
Tiger Lake-U
MEC1515
N17S-G3
N17S-G3-A1_BGA_595P
DA8001QB000
Tiger Lake-U
MEC1515
N17S-G3
N17S-G3-A1_BGA_595P
