Dell Inspiron 15299-1 Schematic
The Wistron Rocket BSW 11.6" motherboard, project code 4PD076010001 with PCB P/N 15239 revision -1, is built around the Intel Braswell-M CPU platform. The system firmware is stored on a 25MX25U1001EMI SPI flash IC. Embedded controller functions are handled by a NUVOTON NPCE985PB1. Audio is provided by a RealTek ALC3234 codec, while system charging is managed by a TI BQ24727 charger IC. The board supports a single channel of DDR3L-1600 memory at 1.35V. A RealTek RTS5176 micro-SD card reader and an AU62596 USB 2.0 hub are present. Thermal monitoring is performed by a NUVOTON NCT7718W sensor, and a ST STM32L151CB sensor hub interfaces with a ST L3GD20 gyro and ST LSM303DG e-compass. Power regulation is handled by multiple SY8286, SYW232DFC, APL5338, APL5930K, NCP81201MNTXG, SY8288CRAC, and S-1339D15-M5001 ICs.
A: The BIOS SPI flash is a 25MX25U1001EMI.
A: The embedded controller is a NUVOTON NPCE985PB1.
Q: What is the charging IC and architecture on this motherboard?
A: The charging IC is a TI BQ24727, with the specific variant being BQ24727RGRR.
Q: What memory type and configuration does this motherboard support?
A: The board supports a single slot of DDR3L-1600 memory at 1.35V on Channel A.
| Model | Rocket BSW 11.6" |
| Project Code | 4PD076010001 |
| Board Number | 15239 |
| Revision | -1 |
| Date | Tuesday, November 10, 2015 |
| Document Number | A31109 |
| CPU Platform | Braswell-M |
| EC / KBC | NUVOTON NPCE985PB1 |
| Audio Codec | RealTek ALC3234 |
| BIOS / SPI Flash | 25MX25U1001EMI |
| Charging IC | TI BQ24727 |
| Charger Architecture | BQ24727RGRR |
| Power IC(s) | SY8286RAC, SY8286BRAC, SYW232DFC, APL5338, APL5930K, NCP81201MNTXG, SY8288CRAC, S-1339D15-M5001 |
| RAM Type | DDR3L-1600 |
| RAM Architecture | DDR3L 1.35V Channel A |
| RAM Quantity / Slots | 1 |
| Card Reader IC | RealTek RTS5176 |
| USB Hub IC | AU62596 |
| LAN IC | RealTek |
| WiFi / WLAN IC | NGFF WLAN & BT combo module |
| Thermal Sensor | NUVOTON NCT7718W |
| Sensor Hub | ST STM32L151CB |
| Gyro | ST L3GD20 |
| E-compass | ST LSM303DG |
4PD076010001
15239
Braswell-M
NPCE985PB1
ALC3234
25MX25U1001EMI
BQ24727
APL5338
APL5930K
NCP81201MNTXG
S-1339D15-M5001
SY8286BRAC
SY8286RAC
SY8288CRAC
SYW232DFC
RTS5176
AU62596
NCT7718W
ST STM32L151CB
Motion / Position Sensor
4PD076010001
15239
Braswell-M
NPCE985PB1
ALC3234
25MX25U1001EMI
BQ24727
APL5338
APL5930K
NCP81201MNTXG
S-1339D15-M5001
SY8286BRAC
SY8286RAC
SY8288CRAC
SYW232DFC
RTS5176
AU62596
NCT7718W
ST STM32L151CB
