dell inspiron 1520 quanta fm5_cosica gilligan_uma_rev2b schematic
dell inspiron 1520=1=quanta fm5_cosica gilligan_uma_rev2b.pdf
The Quanta Computer C & G UMA 2A motherboard, revision 2B, is built around the Intel Merom CPU platform paired with the ICH8-M southbridge. This UMA architecture board supports two DDR2-SODIMM slots for DDR II memory. The embedded controller is an MEC5025 in a 128-pin VTQFP package, featuring 128KB of internal flash for programmability. System BIOS is stored on a dedicated SPI Flash IC. Audio is handled by a STAC9200 codec, while networking is provided by a BCM4401 B0 LOM controller. The charging circuit utilizes a BCCK505 IC, and the CPU core power is regulated by an ISL6260 3-phase VR controller. Thermal management is managed by an EMC4001 sensor, and a R5C833 controller provides card reader functionality.
A: The motherboard uses an MEC5025 EC/KBC in a 128-pin VTQFP package with 128KB of internal flash memory.
A: The charging IC is a BCCK505.
Q: What CPU VR controller is used?
A: The CPU core power is regulated by an ISL6260 3-phase controller.
Q: What audio codec is present?
A: The audio codec is a STAC9200.
| Brand | QUANTA COMPUTER |
| Model | C & G UMA 2A |
| Project Code | C & G UMA 2A |
| Board Number | C&G UMA M/B PCB |
| Revision | 2B |
| Date | Thursday, January 25, 2007 |
| CPU Platform | Merom |
| EC / KBC | MEC5025 |
| EC/KBC Package | 128 Pins VTQFP |
| EC/KBC Programmable | 128KB Flash |
| Audio Codec | STAC9200 |
| Charging IC | BCCK505 |
| Power IC(s) | CPU_ISL6260 (3phase) |
| RAM Type | DDR2-SODIMM |
| RAM Architecture | DDR II |
| LAN IC | BCM4401 B0 |
| WiFi / WLAN IC | MINI-CARD x3 |
| Card Reader IC | R5C833 Controller |
| USB Hub IC | USB X 4 |
| Thermal Sensor | EMC4001 |
