acer aspire 1520_1522_1524 wistron_egret_revsc schematic
acer aspire 1520_1522_1524=1=wistron_egret_revsc.pdf
The Wistron EGRET project, board number A3150 revision A3, is an AMD K8 platform based on the Claw Hammer processor. The system architecture is built around a VIA K8N800 northbridge with integrated graphics and a VIA VT8235CE southbridge. Memory is supported via a single 200-pin DDR SODIMM slot. The embedded controller is an M38859, and the system BIOS is stored on an SST 49LF040 flash IC. Audio is handled by a VT1612A AC'97 codec, while networking is provided by a Realtek RTL8110SBL Gigabit LAN controller. Power management includes a MAX1645BEEI battery charger, a MAX1999 system power IC, and an ISL6559CR CPU core voltage regulator. The platform also features a VIA VT1623M TV encoder and a VIA VT1631 LVDS transmitter for display output.
Q: What BIOS flash IC is used on this motherboard?
A: The system uses an SST 49LF040 flash IC for BIOS storage.
A: The embedded controller is an M38859.
A: The battery charger IC is a MAX1645BEEI.
Q: What is the CPU platform and northbridge configuration?
A: The platform uses an AMD Claw Hammer K8 CPU paired with a VIA K8N800 northbridge.
| Project Code | EGRET |
| Board Number | A3150 |
| Revision | A3 |
| Date | Friday, July 23, 2004 |
| CPU Platform | Claw Hammer K8 AMD CPU |
| PCH / Southbridge | VIA VT8235CE |
| GPU Type | VIA K8N800 |
| EC / KBC | M38859 |
| Audio Codec | VT1612A |
| BIOS / SPI Flash | SST 49LF040 |
| Charging IC | MAX1645BEEI |
| Power IC(s) | MAX1999, APL5508-18VC/APL5308-25A, ISL6559CR, TPS5110, FDS9412-U/SI4892DY/LP2951ACM |
| RAM Type | DDR |
| RAM Architecture | 200-PIN DDR SODIMM |
| LAN IC | Realtek RTL8110SBL |
| WiFi / WLAN IC | 802.11a/b/g Mini-PCI |
| Card Reader IC | PCI 7420 TI |
| USB Hub IC | VIA VT8235CE |
| TV Encoder | VIA VT1623M |
| LVDS Transmitter | VIA VT1631 |
| Clock Generator | ICS950405 |
| Super I/O | NS SIOPC87392 |
| Thermal Sensor | G791 |
| FIR | TFDU6101E |
A3150
Claw Hammer K8 AMD
VT8235CE
K8N800
M38859
VT1612A
49LF040
MAX1645BEEI
APL5308-25A
APL5508-18VC
FDS9412-U
ISL6559CR
LP2951ACM
MAX1999
SI4892DY
TPS5110
DDR
RTL8110SBL
PCI7420 TI
VT8235CE
ICS950405
NS SIOPC87392
Super I/O
G791
A3150
Claw Hammer K8 AMD
VT8235CE
K8N800
M38859
VT1612A
49LF040
MAX1645BEEI
APL5308-25A
APL5508-18VC
FDS9412-U
ISL6559CR
LP2951ACM
MAX1999
SI4892DY
TPS5110
DDR
RTL8110SBL
PCI7420 TI
VT8235CE
ICS950405
NS SIOPC87392
Super I/O
G791
