dell inspiron 15 n5040 wistron dv15cp enricocaruso
This Wistron Corporation Enrico/Caruso 15" UMA motherboard, project code 91.4IP01.001 and board number 48.4IP01.011 revision 10263-1, is built on the Intel Ibex Peak-M platform with an rPGA988A socket for Mobile Arrandale processors. The system management is handled by a VOTON NPCE781BA0DXN EC/KBC, while audio processing is managed by an IDT92HD87B1P codec. Power management is distributed across multiple ICs including an ISL62882 CPU VR controller, RT8237 and RT8207 system DC/DC converters, TPS51123 and TPS51611 regulators, and an APW7153B converter, with battery charging controlled by a BQ24707 MAXIM CHARGER. Memory configuration supports DDRIII 1066 across two slots in Channel A and Channel B. The board features a Realtek RTL8105E-VC 10/100 NIC and an 802.11b/g/n BT V3.0+HS Mini-Card for wireless connectivity, with a 4MB Flash ROM for BIOS storage.
A: The EC/KBC is a VOTON NPCE781BA0DXN.
A: The BIOS is stored on a 4MB Flash ROM.
Q: What charging IC is used?
A: The charging IC is a BQ24707 from Maxim.
A: The board supports DDRIII 1066 memory across two slots configured as Channel A and Channel B.
| Model | Enrico/Caruso 15" UMA |
| Project Code | 91.4IP01.001 |
| Board Number | 48.4IP01.011 |
| Revision | 10263-1 |
| Date | Friday, April 22, 2011 |
| CPU Platform | Intel Ibex Peak-M |
| CPU Socket | rPGA988A |
| EC / KBC | NPCE781BA0DXN |
| EC/KBC Package | VOTON |
| Audio Codec | IDT92HD87B1P |
| BIOS / SPI Flash | 4MB Flash ROM |
| Charging IC | BQ24707 |
| Charger Architecture | MAXIM CHARGER |
| Power IC(s) | ISL62882, RT8237, RT8207, TPS51123, TPS51611, APW7153B |
| RAM Architecture | 1066 Channel A, 1066 Channel B |
| Card Reader IC | RTS5138 |
| LAN IC | Realtek RTL8105E-VC |
| WiFi / WLAN IC | 802.11b/g/n BT V3.0+HS Mini-Card |
| Document Number | CPA00 |
91.4IP01.001
48.4IP01.011
Ibex Peak-M
NPCE781BA0DXN
IDT92HD87B1P
BQ24707
APW7153B
ISL62882
RT8207
RT8237
TPS51123
TPS51611
RTS5138
RTL8105E-VC
n BT V3.0
91.4IP01.001
48.4IP01.011
Ibex Peak-M
NPCE781BA0DXN
IDT92HD87B1P
BQ24707
APW7153B
ISL62882
RT8207
RT8237
TPS51123
TPS51611
RTS5138
RTL8105E-VC
n BT V3.0
