Schematic DELL E5470 LA-C631P Schematic
BrandDell
Motherboard ManufacturerCompal Electronics, Inc.
Document NumberLA-C631P
Revision1.0
DateThursday, October 08, 2015
CPU PlatformIntel Skylake U
PCH / SouthbridgeIntel MCP
EC / KBCSMSC KBC MEC5085
EC/KBC PackageSMSC SIO ECE5048
Audio CodecALC3235
BIOS / SPI FlashW25Q64FVSSIQ
BIOS Flash Capacity128M 4K sector
Compatible BIOS IC ModelsW25Q128FVSIQ
RAM TypeDDR4
RAM ArchitectureDDR4-SO-DIMM X2
LAN ICIntel Jacksonville WGI219LM
Card Reader ICRTS5242
TPMNPCT650JAAYX
TPM 1.2BCM58102
Smart Card ICTDA8034HN
USB Power Share ICTPS2544
SATA/PCIe RepeaterPS8558
DP DeMUXPS8338
SATA RepeaterPI3EQX6741
VGA SwitchTS3V713
LOM SwitchPI3L720
Fingerprint Connector InterfaceSPI
RFID/NFC InterfaceSPI
LID Switch InterfaceSPI
This Dell motherboard, manufactured by Compal Electronics (Document Number LA-C631P Rev 1.0, dated October 8, 2015), is built on the Intel Skylake U platform with an Intel MCP PCH. The system firmware is stored on a W25Q64FVSSIQ SPI flash (128M, 4K sector), with a compatible W25Q128FVSIQ alternative. The embedded controller is an SMSC KBC MEC5085, with an SMSC SIO ECE5048 package. Audio is handled by an ALC3235 HDA codec, and wired networking by an Intel Jacksonville WGI219LM. Memory consists of two DDR4 SO-DIMM slots. Additional notable ICs include an NPCT650JAAYX TPM 2.0, a BCM58102 TPM 1.2, a TDA8034HN smart card controller, an RTS5242 card reader, a TPS2544 USB power share controller, PS8558 SATA/PCIe repeaters, a PS8338 DP DeMUX, a PI3EQX6741 SATA repeater, a TS3V713 VGA switch, and a PI3L720 LOM switch.
Q: What BIOS IC models are used on this motherboard?
A: The primary BIOS flash is a W25Q64FVSSIQ (128M, 4K sector). A compatible alternative is the W25Q128FVSIQ.
A: The embedded controller is an SMSC KBC MEC5085, with an SMSC SIO ECE5048 package.
A: The motherboard supports DDR4 memory via two DDR4 SO-DIMM slots.
  • DELL E5470 LA-C631P Schematic.pdf
