dell 5437 wistron doe40 hsw 12314-1
This Wistron Corporation reference design, project code 4PD00I010001, is documented as Janus HSW 40/50/70X02 revision -1, dated February 7, 2014. The platform is based on an Intel WPT-LP CPU, supporting Broadwell ULT processors in both 28W UMA and 15W DIS configurations. The discrete GPU is an NVIDIA N15V-GM-S-A2 GB2-64 (23x23) rated at 25W. System memory consists of DDR3L 1333/1600 MHz across four 2GB SODIMM modules on Channel A. The embedded controller is an NPCE285P, with an APL5606AKI EC flash ROM. The BIOS is stored on an 8MB Quad Read SPI flash. Audio is handled by an ALC3234 codec. The charging IC is an HPA02224RGRR-1-GP, supported by power ICs including ISL95813HRZ-GP, TPS51225RUKR-GP, RT8237CZQW-2-GP, and TLV70215DBVR-GP. LAN connectivity is provided by either an RTL8106E (Cedar) or RTL8111G (Janus), with an integrated 802.11a/b/g/n BT V4.0 combo WLAN module. The card reader uses an RTS5170, and HDMI level shifting is performed by an RTD2168. Thermal monitoring is managed by an NCT7718W sensor.
A: The BIOS is stored on an 8MB Quad Read SPI flash ROM.
Q: What EC/KBC is used and is it programmable?
A: The embedded controller is an NPCE285P, with a dedicated APL5606AKI EC flash ROM.
Q: What is the charging architecture?
A: The charging IC is an HPA02224RGRR-1-GP, with system power managed
| Project Code | 4PD00I010001 |
| Board Number | Janus HSW 40/50/70X02 |
| Revision | -1 |
| Date | Friday, February 07, 2014 |
| CPU Platform | Intel CPU WPT-LP |
| CPU Model | Broadwell ULT 28W (UMA) 15W (DIS) |
| GPU Type | NVIDIA N15V-GM-S-A2 GB2-64 ([URL="https://dr-bios.com/components/graphics-models/23x23/"]23x23) 25W[/URL] |
| EC / KBC | NPCE285P |
| Audio Codec | ALC3234 |
| BIOS / SPI Flash | 8MB Quad Read |
| Charging IC | HPA02224RGRR-1-GP |
| Power IC(s) | ISL95813HRZ-GP, TPS51225RUKR-GP, RT8237CZQW-2-GP, TLV70215DBVR-GP |
| RAM Type | DDR3L |
| RAM Architecture | DDR3L 1333/1600MHz Channel A |
| RAM Quantity / Slots | 2GB *4 |
| Card Reader IC | RTS5170 |
| LAN IC | RTL8106E (Cedar), RTL8111G (Janus) |
| WiFi / WLAN IC | 802.11a/b/g/n BT V4.0 combo |
| HDMI Level Shifter | RTD2168 |
| Thermal Sensor | NCT7718W |
| EC Flash / ROM | APL5606AKI |
| Document Number | A43 |
| PCB P/N | 12314-15544332211DDCCBBAA |
4PD00I010001
JANUS HSW 40/50/70X02
Wildcat Point
23x23
N15V-GM-S-A2 GB2-64 25W
NPCE285P
ALC3234
HPA02224RGRR-1-GP
ISL95813HRZ-GP
RT8237CZQW-2-GP
TLV70215DBVR-GP
TPS51225RUKR-GP
RTL8106E
RTL8111G
n BT V4.0 combo
RTD2168
NCT7718W
APL5606AKI
4PD00I010001
Wildcat Point
23x23
NPCE285P
ALC3234
HPA02224RGRR-1-GP
ISL95813HRZ-GP
RT8237CZQW-2-GP
TLV70215DBVR-GP
TPS51225RUKR-GP
RTL8106E
RTL8111G
n BT V4.0 combo
RTD2168
NCT7718W
APL5606AKI
