dell 17r compal la-9984p vbw11_rev1.0 schematic
dell 17r=1=compal la-9984p vbw11_rev1.0.pdf
This Dell VBW11 motherboard, manufactured by Compal Electronics under project code ANRVBW0100, is built on the Intel Shark Bay ULT OAK Mainstream platform with an Intel Haswell Processor 15W DC BGA1168 and Intel Lynx Point-LP PCH. The board supports both UMA and discrete graphics configurations, with the discrete option being an AMD Venus Pro (HD8850M) 2GB GDDR5 GPU. System memory consists of two DDRIII-DIMM slots running DDR3L in dual-channel configuration. The embedded controller is an ENE KBC KB9012, and the audio codec is an ALC3223. Networking is handled by a Realtek RTL8106E Ethernet controller, with WLAN/BT4.0 support. The board also features an RTS5179/5170 card reader controller and an RTD2136R HDMI level shifter. The primary BIOS is stored on a SPI ROM.
A: The motherboard uses an ENE KBC KB9012 embedded controller.
Q: Does this motherboard support dGPU to UMA conversion?
A: Yes, the schematic includes BOM configuration options for UMA@, DIS@, VENUS@, and VENUSXT@, allowing conversion between discrete and UMA graphics.
Q: What is the RAM configuration on this motherboard?
A: The motherboard supports two DDRIII-DIMM slots with DDR3L memory in a dual-channel architecture.
A: The audio codec is an ALC3223.
| Model | VBW11 |
| Project Code | ANRVBW0100 |
| Board Number | DA8000WN000 LA-9984P M/B |
| Date | 2013-05-17 |
| CPU Platform | Intel Shark Bay ULT OAK Mainstream |
| CPU Model | Intel Haswell Processor 15W DC BGA1168 |
| PCH / Southbridge | Intel Lynx Point-LP |
| GPU Type | AMD Venus Pro (HD8850M) 2GB GDDR5 (128Mx16x8pcs) |
| Graphics Architecture | UMA / DIS AMD Venus XT |
| dGPU Chip Number | AMD Venus Pro , 25W |
| dGPU to UMA Conversion Support | UMA@,DIS@,VENUS@,VENUSXT@ |
| EC / KBC | ENE KBC KB9012 Int. |
| Audio Codec | ALC3223 |
| BIOS / SPI Flash | SPI ROM |
| RAM Type | DDR3L |
| RAM Architecture | Dual Channel Memory Bus (DDR3L) |
| RAM Quantity / Slots | DDRIII-DIMM X2 |
| LAN IC | RTL8106E |
| WiFi / WLAN IC | WLAN/BT4.0 |
| Card Reader IC | RTS5179/5170 |
| HDMI Level Shifter | RTD2136R |
| Document Number | LA-9984P |
ANRVBW0100
Shark Bay-ULT
128Mx16x8pcs
HD8850M
25W
KB9012 INT
ALC3223
RTL8106E
WLAN + BT4.0
RTS5179/5170
RTD2136R
ANRVBW0100
Shark Bay-ULT
128Mx16x8pcs
HD8850M
25W
KB9012 INT
ALC3223
RTL8106E
WLAN + BT4.0
RTS5179/5170
RTD2136R
