compal la-1711 rev a00-b
This DELL LA-1711 Rev A00-B schematic, dated January 28, 2004, details the Prescott & Springdale platform featuring a uFCPGA Prescott CPU and Springdale GMCH (RG82865PE A2) graphics architecture. The platform utilizes an ICH5 southbridge and supports DDR memory across two SO-DIMM channels, each with four banks. The BIOS flash is an SST39VF080, and the system audio is handled by a STAC9750 codec. Networking is provided by both BCM5705M and BCM4401 LAN ICs, with a MINI PCI slot for WLAN. The design includes an ADT7460 thermal sensor, a PCI4510 card reader, and a dedicated CHARGER IC. The EC/KBC function is managed by an LPC to X-BUS & Super I/O controller.
A: The BIOS flash is an SST39VF080.
Q: What is the graphics architecture of this platform?
A: The graphics architecture is Springdale (GMCH), using the RG82865PE A2 (SL722) GPU.
Q: What LAN ICs are used on this motherboard?
A: The motherboard uses both a BCM5705M and a BCM4401 LAN IC.
Q: What type of memory does this platform support?
A: The platform supports DDR memory across two SO-DIMM channels, Channel A and Channel B, each with four banks.
| Brand | DELL |
| Document Number | LA-1711 |
| Revision | A00-B |
| Date | Wednesday, January 28, 2004 |
| CPU Platform | Prescott & Springdale |
| CPU Socket | uFCPGA |
| PCH / Southbridge | ICH5 |
| GPU Type | RG82865PE A2 ([URL="https://dr-bios.com/components/graphics-models/sl722/"]SL722)[/URL] |
| Graphics Architecture | Springdale (GMCH) |
| EC / KBC | LPC to X-BUS & Super I/O |
| Audio Codec | STAC9750 |
| BIOS / SPI Flash | SST39VF080 |
| Charging IC | CHARGER |
| RAM Architecture | Channel A SO-DIMM, Channel B SO-DIMM |
| RAM Quantity / Slots | BANK 0, 1, 2, 3 (Channel A), BANK 0, 1, 2, 3 (Channel B) |
| Thermal Sensor | ADT7460 |
| Card Reader IC | PCI4510 |
| LAN IC | BCM5705M, BCM4401 |
| WiFi / WLAN IC | MINI PCI |
| HDMI Level Shifter | TV-OUT |
Prescott
Springdale
ICH5
RG82865PE A2
SL722
Springdale (GMCH)
STAC9750
SST39VF080
DDR
ADT7460
PCI4510
BCM4401
BCM5705M
Prescott
Springdale
ICH5
RG82865PE A2
SL722
Springdale (GMCH)
STAC9750
SST39VF080
DDR
ADT7460
PCI4510
BCM4401
BCM5705M
