Schematic ASUS FX506 Quanta NJJ DANJJMB1AA0 Schematic
BrandASUS
ModelFX506H
Motherboard ManufacturerQuanta Computer Inc.
Project CodeNJJ162
Revision1A
DateTuesday, June 08, 2021
CPU PlatformTiger Lake - H 8+2
GPU TypeNVIDIA GN20-P0/P1 N18P-G61-A
Graphics ArchitectureVRAM GDDR6x 4 pcs 2CHx256Mx16
EC / KBCITE IT5570VG-128/DX
Audio CodecALC3251-CG
BIOS / SPI FlashSPI ROM
Charging ICTI PD TPS65992
RAM TypeDDR4 3200MHz
RAM ArchitectureChannel A / Channel B
RAM Quantity / SlotsSODIMM1 Max. 16GB / SODIMM2 Max. 16GB
LAN ICRTL8111K / RTL8125
WiFi / WLAN ICWLAN / BT ( CNVi & PCIe ) M.2 2230
HDMI Level ShifterPS8409A
PCH / SouthbridgeTGL PCH
dGPU Chip NumberGN20-P0/P1 N18P-G61-A
The ASUS FX506H motherboard, designed by Quanta Computer Inc. under project code NJJ162 revision 1A, is built around an Intel Tiger Lake-H 8+2 CPU platform paired with a TGL PCH. Graphics are handled by an NVIDIA GN20-P0/P1 N18P-G61-A dGPU with GDDR6x VRAM configured as 4 pcs 2CHx256Mx16. The system memory architecture supports DDR4 3200MHz across two SODIMM slots, each supporting up to 16GB, organized as Channel A and Channel B. The embedded controller is an ITE IT5570VG-128/DX, and the audio codec is an ALC3251-CG. The BIOS is stored on a SPI ROM. Charging is managed by a TI PD TPS65992 controller. Networking includes an RTL8111K or RTL8125 LAN IC and a CNVi/PCIe M.2 2230 WLAN/BT module. HDMI connectivity is supported via a PS8409A re-driver.
Q: What is the EC/KBC model used on this motherboard?
A: The embedded controller is an ITE IT5570VG-128/DX.
Q: What is the dGPU configuration on this motherboard?
A: The dGPU is an NVIDIA GN20-P0/P1 N18P-G61-A with GDDR6x VRAM, 4 pcs 2CHx256Mx16.
A: The motherboard supports DDR4 3200MHz memory across two SODIMM slots, each supporting up to 16GB, configured as Channel A and Channel B.
A: The charging IC is a TI PD TPS65992.
Q: What LAN and WLAN ICs are used?
A: The LAN IC is an RTL8111K or RTL8125, and the WLAN/BT module uses a CNVi & PCIe M.2 2230 interface.
  • ASUS FX506 Quanta NJJ DANJJMB1AA0 Schematic.pdf
