Schematic asus a93s x93s x93sv k93sv ls-7441p rev 0.1 usb 0117bom schematic
BrandCompal
Project CodePBL80
Board NumberLS-7441P
Revision0.1
Date2011-01-17
Motherboard ManufacturerCompal Electronics, Inc.
Document NumberLS-7441P
This Compal Electronics LS-7441P USB board, project code PBL80, is documented under revision 0.1 with a date of January 17, 2011. The schematic is designated as a USB board, featuring multiple USB connectors and associated power switching and ESD protection components. Key components include AP2301SG power distribution switches in SO-8 packages and YSDA0502C ESD protection diodes in SOT-23 packages. The board utilizes ferrite beads (WCM-2012-121T) and various decoupling capacitors for signal integrity and power filtering. The document is marked as Compal confidential and is intended for internal engineering use.
Q: What is the board number and project code for this USB board?
A: The board number is LS-7441P and the project code is PBL80.
Q: What is the revision and date of this schematic?
A: The schematic revision is 0.1 and the date is January 17, 2011.
Q: What power switch ICs are used on this board?
A: The board uses AP2301SG power distribution switches in SO-8 packages at U1A and U2A.
  • Asus_A93S_X93S_X93SV_K93SV=LS-7441P_Rev_0.1_usb_0117bom_DR-BIOS.COM.zip
