airis kira series quanta il1 da0il1mb6b0_rev1a schematic
airis kira series=1=quanta il1 da0il1mb6b0_rev1a.pdf
This Quanta IL1 project motherboard is built around the VIA C7-M (ULV) processor and VX800(U) chipset. The system integrates a KB3310 embedded controller, an ALC267 HD audio codec, and an RTL8100CL 10/100 Ethernet controller. Storage expansion is handled by an SM223 NAND flash controller supporting 1/2/4 GB NAND flash, alongside a P10403 3-in-1 card slot for CR/SD/MMC/MS media. The clocking solution is provided by an ICS9UM701 clock generator. The charging architecture is designated as B --> C.
Q: What embedded controller is used on this Quanta IL1 motherboard?
A: The EC/KBC is a KB3310.
Q: What audio codec is integrated on this board?
A: The audio codec is an ALC267.
Q: What LAN controller is used on this motherboard?
A: The LAN IC is an RTL8100CL.
Q: What card reader controller is present?
A: The card reader IC is an SM223, supporting NAND flash of 1/2/4 GB.
| Project Code | IL1 |
| Date | Friday, January 11, 2008 |
| CPU Platform | C7-M (ULV) |
| PCH / Southbridge | VX800(U) |
| EC / KBC | KB3310 |
| Audio Codec | ALC267 |
| LAN IC | RTL8100CL |
| Card Reader IC | SM223 |
| Clock Generator | ICS9UM701 |
| Charger Architecture | B --> C |
