Acer VN7-592G Rayleigh_SLS 32B 15292-1
The Wistron Rayleigh_SLS motherboard, documented under project code Rayleigh_SLS and document number Rayleigh_SLSSA revision A1, is built around the Intel Skylake-H CPU platform paired with the PCH-H HM170 chipset. Graphics processing is handled by an Nvidia N16P-GX GPU with GDDR5 memory. The system firmware resides on an 8MB SPI flash IC. Embedded controller functionality is provided by a KB9038Q controller. Audio is managed by a Realtek ALC255 codec, while networking is supported by a Realtek RTL8111H LAN IC and WiGig/Wi-Fi wireless module. Memory configuration consists of two DDR4-RS SO-DIMM slots supporting 1867/2133 MHz speeds. The charging IC is an HPA0222, and the HDMI interface utilizes a TPS65982 level shifter. Additional I/O includes a G3703 USB hub IC and an RTS5170 card reader controller.
A: The motherboard uses an 8MB SPI flash IC for system firmware storage.
A: The embedded controller is a KB9038Q.
A: The dedicated GPU is an Nvidia N16P-GX with GDDR5 memory.
A: The motherboard supports DDR4-RS memory at 1867/2133 MHz via two SO-DIMM slots.
| Project Code | Rayleigh_SLS |
| Document Number | Rayleigh_SLSSA |
| Revision | A1 |
| Date | Wednesday, August 12, 2015 |
| CPU Platform | Skylake-H |
| PCH / Southbridge | PCH-H HM170 |
| GPU Type | Nvidia N16P-GX |
| Graphics Architecture | GDDR5*8 |
| EC / KBC | KB9038Q |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | 8MB SPI Flash |
| Charging IC | HPA0222 |
| RAM Type | DDR4-RS 1867/2133 |
| Card Reader IC | RTS5170 |
| LAN IC | Realtek RTL8111H |
| WiFi / WLAN IC | WiGig / Wi-Fi |
| USB Hub IC | G3703 |
| HDMI Level Shifter | TPS65982 |
