acer aspire vn7-792g newgate 14307-1m schematic
acer aspire vn7-792g=1=newgate 14307-1m.pdf
The Wistron Newgate motherboard, project code 4PD06A010001 and PCB P/N 14307 revision 1, is built around the Intel Skylake-H CPU platform paired with the PCH-H HM170 chipset. Graphics processing is handled by an Nvidia N16P-GX GPU with GDDR5 memory. The system firmware resides on an 8MB SPI flash IC, while system management is controlled by a KB9038QA EC/KBC. Audio is managed by an ALC255 codec and an ALC100135 amplifier. Charging is handled by an HPA02224 IC communicating over SMBus. Memory configuration supports DDR4-RS at 1867/2133 MHz across two SO-DIMM slots arranged in Channel A and Channel B. Connectivity includes a Realtek RTL8111H LAN controller, Wi-Fi 6 wireless, and an RTS5170 card reader.
A: The board number is 14307, and the project code is 4PD06A010001.
A: The EC/KBC is a KB9038QA.
A: The BIOS flash capacity is 8MB.
Q: What charging IC and architecture does this motherboard use?
A: The charging IC is an HPA02224, and the charger architecture uses SMBus communication.
| Model | Newgate |
| Project Code | 4PD06A010001 |
| Board Number | 14307 |
| Revision | 1 |
| Date | Wednesday, August 12, 2015 |
| CPU Platform | Skylake-H |
| PCH / Southbridge | PCH-H HM170 |
| GPU Type | Nvidia N16P-GX |
| Graphics Architecture | GDDR5*8 |
| EC / KBC | KB9038QA |
| Audio Codec | ALC255 |
| BIOS Flash Capacity | 8MB |
| Charging IC | HPA02224 |
| Charger Architecture | SMBus |
| RAM Type | DDR4-RS 1867/2133 |
| RAM Quantity / Slots | SO-DIMM1, SO-DIMM2 |
| Card Reader IC | RTS5170 |
| LAN IC | RTL8111H |
| WiFi / WLAN IC | Wi-Fi 6 |
| Audio Amplifier | ALC100135 |
4PD06A010001
14307
Skylake-H
HM170
N16P-GX
GDDR5*8
KB9038QA
ALC255
HPA02224
DDR4 RS
RTS5170
RTL8111H
Wi-Fi 6
ALC100135
4PD06A010001
14307
Skylake-H
HM170
N16P-GX
GDDR5*8
KB9038QA
ALC255
HPA02224
DDR4 RS
RTS5170
RTL8111H
Wi-Fi 6
ALC100135
