Acer Travelmate P852-QG 6-7P-P9508-001 Schematic
This Acer TravelMate P852-QG motherboard schematic, revision D03 dated June 23, 2017, is based on the P955HQx project with board number 6-71-P9500-D03. The platform utilizes an Intel Kabylake H-processor paired with an HM175 Platform Controller Hub (PCH-H). Graphics are handled by an N17E-Q1 MAX-P or N17E-Q3 MAX-Q GPU. The embedded controller is an ITE 8587A with 512KB ROM. System memory consists of two DDR4 SO-DIMM slots. The audio subsystem features a Realtek ALC1220 codec and an ALC1305 Smart AMP. Networking is provided by a Realtek RTL8111G LAN IC and a WLAN+BT module. The charging IC is an SV3H612, and a Realtek RTS5250 manages the card reader. A USB 3.1 Type-C interface is supported via an ASM 2142 hub controller.
A: The main motherboard board number is 6-71-P9500-D03, and the project code is P955HQx.
A: The embedded controller is an ITE 8587A with 512KB ROM.
Q: What GPU options are supported on this motherboard?
A: The schematic supports N17E-Q1 MAX-P and N17E-Q3 MAX-Q GPU configurations.
Q: What is the charging IC used on this motherboard?
A: The charging IC is an SV3H612.
| Brand | Acer |
| Model | TravelMate P852-QG |
| Motherboard Manufacturer | P950HP M/B BOARD |
| Project Code | P955HQx |
| Board Number | 6-71-P9500-D03 |
| Revision | D03 |
| Date | Friday, June 23, 2017 |
| CPU Platform | Kabylake H-processor |
| PCH / Southbridge | HM175 Platform Controller Hub (PCH-H) |
| GPU Type | N17E-Q1 MAX-P / N17E-Q3 MAX-Q |
| EC / KBC | ITE 8587A (512KB ROM) |
| Audio Codec | Realtek ALC1220 |
| BIOS / SPI Flash | SPI |
| RAM Architecture | SO-DIMM*2 |
| LAN IC | RTL8111G |
| WiFi / WLAN IC | WLAN+BT |
| Card Reader IC | Realtek RTS5250 |
| USB Hub IC | ASM 2142 |
| Charging IC | SV3H612 |
| Smart AMP | ALC1305 |
| Document Number | 6-7P-P9508-002 |
| Drawing Number | 6-7P-P9508-002 |
| PCB Number | 6-71-P9500-D03 |
| Schematic Number | 6-7P-P9508-002 |
