Acer Swift SFX16-51G Compal HH6FH LA-L701P Rev 1A Schematic
This Compal HH6FH MB schematic, revision 1.A dated June 28, 2021, documents the Baltika_TLM project under the LA-L701P document number. The platform is built around a dual-channel LPDDR4X 4266 memory architecture with on-board x32 memory modules. The block diagram indicates support for PCIe 3.0 x4 at 8GT/s on multiple ports, HDMI with 4 lanes via DDI2, and a 3.3V 24MHz clock source. The system also features a 48MHz HD Audio bus, LPC/eSPI bus, and USB connectivity. The schematic is classified as Compal Secret Data and is proprietary to Compal Electronics, Inc.
A: The board number is HH6FH MB, and the project code is LA-L701P under the model name Baltika_TLM.
Q: What memory architecture is used on this motherboard?
A: The motherboard uses dual-channel LPDDR4X 4266 memory with on-board x32 modules.
Q: What revision is this schematic?
A: The schematic is revision 1.A, dated June 28, 2021.
| Model | Baltika_TLM |
| Project Code | LA-L701P |
| Board Number | HH6FH MB |
| Revision | 1.A |
| Date | 2021.06.28 |
| Document Number | LA-L701P |
| RAM Type | LPDDR4X |
| RAM Quantity / Slots | On Board |
